M30 hard miss
  • Syncro325is
    • 574
    M30 hard miss
    Ricksloan and I are trying to get his m30 car running again and not having any luck. We have changed the afm, ecu, coil wire, checked compression on cylinder one, checked the first three injectors, and the car still has a consistent hard miss and an occasional extreme backfire. Any helpful ideas?
  • RickSloan
    • 2401
    Anybody... :(
    Need Illustration or Design work? www.robbiebyerly.com
    • walktheboard
      • 347
      when does it happen?
      could be CPS related?
      Originally posted by e30hijinks
      I move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play games
      • RickSloan
        • 2401
        All the time, car will idle but has a hard miss constantly and if you gently give it throttle you can rev it but it is missing the entire time. If you hit the throttle hard it dies for a second and falls on its fface...
        • Jean
          • 18228
          the "hit gas" and it wants to die makes me want to check the TPS....
          the otherwise miss at all times? check the basics such as ignition/coil/wires and maybe even fuel pressure ?
          • LowR3V'in
            • 4209
            Hello.
            To me that sounds allot like it's going to be the main relay or a lose connection on the injector harness.
            Good luck!
            • kylelauffer
              • Dec 2009
              • 624
              the only time my car back fired was when i messed with mass air flow. check all spark plugs after running it. see if all are burning or rich with fuel.
              • Doughnut
                • Oct 2007
                • 869
                Check all spark plugs/ leads and check the rotor and cap for wear.
                ///Monstrosity. (OO≡≡[][]≡≡OO)
                Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                • RickSloan
                  • 2401
                  ok checked wiring yesterday, cleaned all my grounds, cleaned up some wiring that was messy. Need to clean a connector, has some corrosion but not a lot...
                  still missing hard. gonna pull the cap and rotor today hopefully and then the rest of the spark plugs
                  • MrBme30
                    • Jun 2011
                    • 1
                    E30 Hard miss
                    My car (325i-89) has also an engine hard miss failure. The problem started after a head on collision at ~20MPH. The hard miss and backfire symptoms described in this thread (#1) are similar to my car's failure mode. So, I would like to ask, was there any event or condition that could have initially caused the problem on Ricksloan's engine?
                    After the collision, I had the car's body repaired and the distributor cap, rotor, water pump, and radiator replaced. So far, I have not been able to identify the cause of the engine miss/backfire.
                    • RickSloan
                      • 2401
                      you should check that your exhaust isn't bent and replace the spark plugs, im replacing mine hopefully today, looks like that might have been the issue
                      • rav320uk
                        • Jun 2004
                        • 1337
                        Have you checked the Blue temp switch on the engine??
                        Maybe faulty causing it to run very rich.
                        If you have bought items from me, please leave feedback below.
                        If you are a BUYER, Check My Feedback.:up:
                        http://www.r3vlimited.com/board/showthread.php?t=183860
                        Check out my Euro Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=215557
                        • Jb325is
                          • 2137
                          Check the fuel pressure regulator, the diaphragm broke in mine and I had similar issues. Have you checked the condition of the plugs?
                          - '88 m54 coupe
                          <3
                          • Syncro325is
                            • 574
                            I have ordered new plugs for him, yet have forgotten them at work for the past week. We shall see what they do.
                            • RickSloan
                              • 2401
                              this and i will switch out the FPR today as well
