I had a 91 BMW 325IS. unfortunately I was not satisfied with the power.
In a means to enhance the power I did a M30B35 swap. While running the car a cotter key fell into the intake manifold and surprisingly enough did not hit the valve. I decided to resurface everything and turbo it.
The First Set up:
745I turbo manifold machine for T3 flange
Garrett GT35R 1.06 exhaust housing
23x7 inter cooler
Miller turbo package 36lb injectors 4in MAF War chip.
Dyno:
256 HP
365TQ
Eventually I got an exhaust leak with the 745i turbo manifold...
So I decided to change a couple things.
New parts:
Good&tite turbo manifold
Head studs and thicker head gasket
non inter cooled
water injection
38mm Wastegate.
Bottom mounted 35r with 745i turbo manifold
Good&tite Turbo manifold (very nice by the way! highly recommended!)
The First Set up:
23x7 inter cooler
Dyno:
256 HP
365TQ
New parts:
non inter cooled
water injection
38mm Wastegate.
