I have a problem with my build, the engine turns on the starter but is not getting fuel.
This is what I have so far;
-Pin 7 has power when key is turned on and when starting
-pump relay has 2 red +, de green wires don't get power when starting/key on, when putting the brown to earth the relay does click.
-Fuse 11 has no power, ever
-Injectors have power
-pin 15 from engine cable connected to ground gives fire...not doing that again.
-no 'humming' in the enginebay when turning the key
-ECU has got power, instruments/lights/fan etc work
Any ideas why the pump doesn't get any spark?
I also changed the two connectors for crankshaftsensor and sparkplug, no effect.
