This happened pulling out at 2500rpm, and I had just set the lash to 0.008 @ the cam cold - maybe a bit tight, but that should run poorly + burn valves, not snap a rocker. TBH I honestly think it was just mechanical failure, was running like a champ right before it happened.
M30 turbo just snapped a rocker, top end advice?
For the valve springs you best go to a good engine shop and have them check your spring pressures and let them decide what you should do. When I say go to a good engine shop I mean real GOOD I work at one and I've seen some big Fuck ups by other shops who have been in the business for over 40 years. They should have the special equipment to precisely check your valve springs. You might as well do it while your getting your head blue printed. And let them recommend you a place that does good cam regrinds.
That's what I'd do anyway.
I shopped around cam shops and am going with IE, they quoted me a reasonable price and seem knowledgeable. I'll be running a turbo cam with a bit more lift than a schrick, hopefully. M30 heads are pretty lift limited on valve curtain area, so it should pick up some nice power. I'll have them recommend valve springs, I think, the whole package from there won't be too bad. If my clutch holds maybe I can crack 600rwhp on 22psi+93+meth'89 335is +turbo
600 whp sounds good to me :D i would not be complaining haha-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good looking
Paul is definitely awesome, but I was trying to keep this to a budget. His stuff would be slightly spendier, I think, though his turbo cam was a good deal last I checked.Originally posted by browntown View Postcall paul burke to discuss, you can find his number somewhere on mye28
I can't think of anyone who knows the m30 better, that is so available as paul'89 335is +turbo
