M30 guys how are they holding up?
  • rs4pro3
    • 5808
    Any problems encountered by anybody? overheating? etc... Just wondering as I'm trying to decide if I want to redo the M30 swap when I have funds, or go a different route. My screwed up M30 discouged me but I miss the power so much.
    85 325e 2.7 ITB'd stroker
  • george graves
    • 19996
    No overheating that I know of - (temp gauage busted! Still!) I've got to do something about that!
    The new stock m20 rubber motor mounts I used are about toast (been about a year). They are very deformed. Vieved from the front or rear they look like a parallelogram rather then a square.
    Motor still pulls like a tractor - and almost as smooth as a m20 (well a bit buzzy up real high)
    Everything seems to be holding together well (execpt tranny/motor mounts) - that was expected.
    Diff seems to handle the added TQ (3.73 LSD).
    I've had some aweful front tire wear but that was due to some ansy broken control arms. I think....
    Ely, How FUBAR is your motor?
    EDIT - on the only thing I HATE - 14-18 MPG!!!! (insert a long string of cuss words here)
    Originally posted by Matt-B
    • rs4pro3
      • 5808
      Blown rings more then likely. It's been stripped down, I'd have to find a good short block to start with if I do the swap again.
      • george graves
        • 19996
        Go 3.5 or a L-block!
        • bmw335ist
          • Apr 2004
          • 100
          the m30 love
          my freind lovenbmw's has the newer m30 he loves it.
          my car is striped and I am going to start over about the first of the year
          • rs4pro3
            • 5808
            Ya it would either be a 3.5, a Euro, or a 3.3 with a high duration cam and some light port work. I loved the 3.3 as it was a very revable engine, once I stuck the 3.5 it lost it's low end grunt but would take off like a mofo from 3k on.
            I believe on my block also I had a coolant passage blocked, as every time I removed the block drain, the watter would barely come out like it was clogged or something.
            • JPbmw
              • 466
              Ely what ever happend to your car? i didnt know you were having trouble with it :|
              '86 325
              • rs4pro3
                • 5808
                Less then 1-month old Alternator belt snapped, Battery light never came on as the Alt was high output so the car was able to run off the battery for a good while, By the time I realized it was to late(heavy interstate traffic). Engine overheated and blew the rings(lost compression and head and gasket checked out A+). Due to past frame damage I parted the car and purchased an 85 325e with 40k on a rebuilt eta engine.
                • JPbmw
                  • 466
                  so what are your plans for it?
                  '86 325
                  • rs4pro3
                    • 5808
                    I'm unsure, I've swapped suspension, interior etc.. over to it but can't decide what engine if any to swap into it.
                    • Operator62
                      • Jul 2005
                      • 119
                      Ely, which transmission did you use? I can't remember. I'm kind of need of a crossmember seeing as how the 318i's won't work. It isn't wide enough. I also need the shifter thingy. lol Not the rod, but where the ball part of the shift lever sits in. Actually, I've got a lot of questions for you Ely. Would you mind if I instant messaged you sometime soon. I've gotten my motor and tranny dropped in. Just needing a few more parts to make things right.
                      • george graves
                        • 19996
                        Ely - M3 Ryan and I (ok him) fixed my temp gauage - it seems as if there theren are two temp sensors in the m20 harness - and some (one two) were mixed - we spliced two wires and at lest one of them got my temp gauage working - here what I've learned.
                        My temp gauage is reading totally normal - it warm up much faster then a m20 motor (use to take 5 mins to get up to temp with a m20 - now it like 2 mins)
                        I tested it buy doing a hard free run (lots of 40-80 pulls) pulled off the freeway and got behind a big truck in a fastfood restruant drive thru line. Idle'd for 10 mins behind a huge truck - never went beyond 1/2 mark.
                        Once it did it didn't want to go back down till I left and hit 40mph on a side street - the it dropped back to the usuall mark(40% out of 100%)
                        The motor runs differently - either I was running full rich before or I am now - time at the gas pump will tell (don't trust the OBC yet) - Decell is defiently different - but low rpm's suck now, motor needs a few revs to get off the line, before I could start off in second at idle and not touch the gas till I was rooling....
                        I'll keep you up to date - Ryan's euro m30 was awesome - I can't imagine a l-block in a e30 - that would be such a amazing motor. IT reves so freely, but you do need 91 pump gas...urrr - that's $3.44 here right now...
                        Let me know what up - later!
                        • rs4pro3
                          • 5808
                          ok cool George, sounds like the engine temp sender for the ecu isn't reading correctly now.
                          I used a Getrage 260/6 tranny and an e30 cross member with e30 tranny mounts(had to shim slightly).
                          • Operator62
                            • Jul 2005
                            • 119
                            Ahhh, I see. Well, I guess I am in search of an M3 crossmember. Any ideas on how much that'll cost? It's either that, or I make one. I've got an older tranny apparently and it's mounts are different.
                            • george graves
                              • 19996
                              I paid $5 for mine from a guy on the sig
