M30 guys how are they holding up?
  • bmw335ist
    • Apr 2004
    • 100
    Re: M30 guys how are they holding up?
    Originally posted by rs4pro3
    Any problems encountered by anybody? overheating? etc... Just wondering as I'm trying to decide if I want to redo the M30 swap when I have funds, or go a different route. My e some screwed up M30 discouged me but I miss the power so much.
    I Have one problem with my turbo m30 with the TCD kit the car fell apart the motor had so much power the e30 could not handle it, but I will start over trust me their is nothing like pulling up to a new m3 and blowing his doors off just my opinon keep with the m30 I am going to rebuild and after I do after being in the Hospital for 2 months and a week I have some safty aspects to do first.
    Just my opinon the 4 point seat belts worked good if I did not have them I would have broken more bones.
    • nefarious7907
      • Jan 2005
      • 1170
      what the website with all the info on the M30 swap, not the 335i.de one I know I going to do a motorswap but which one I dont know, but the ETA has got to go.
      http://www.cardomain.com/ride/657387
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        e30.de
        • 88325isboy
          • Mar 2004
          • 1058
          George Graves were is your car leaking oil from? when i had my m30 in there was a little metal piece on the engine cradle and it punched a hole in the oil pan and damn that thing leaked like a mofo.
          '87 325 (Track Rat)
          '04 C5500 Wrecker (Work)
          '94 525i (Daily)
          '90 325i (R.I.P)
          H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
          • Madhatter
            • Oct 2004
            • 966
            e30.de
            got a feeling he might mean this one
            Just a little project im working on
            - http://www.lse30.com -
            • george graves
              • 20003
              Did I say it's leaking oil? Oh, I valve cover nuts got a bit loose. But otherthan that the block is nice and clean - just like I painted it.
              Originally posted by Matt-B
              • nefarious7907
                • Jan 2005
                • 1170
                http://www.jaredsquires.com/ndp/content/view/17/31/
                no it wasnt either one of those, it had pictures of a couple of other motor swaps and it had a really thorough write up on the m30 swap and it claimed it was the home of the M30 swap. the menu bar was on the and the it had drop down menus from the top menu bar. Any idea what I talking about? the other swap pictures they had included the F20, SR20 DET,LS1, M5x,S5x,.
                • Madhatter
                  • Oct 2004
                  • 966
                  well you cant get much more comprehensive than that.
                  • lovnbmws
                    I rebuilt a getrag 260 at a racetrack and all i got was this stupid title.
                    • Mar 2004
                    • 104
                    Originally posted by Operator62
                    Ahhh, I see. Well, I guess I am in search of an M3 crossmember. Any ideas on how much that'll cost? It's either that, or I make one. I've got an older tranny apparently and it's mounts are different.
                    I’m assuming your using a Getrag 265… some of the e28 528e and a few 535i came with this tranny and different bell housings. It looks just like the e30 260 mount but its wide enough to straddle the 265. You have to slot the mounting holes that bolt it to the car in order to use it.
                    But good luck finding one. 335ist and I found one in a junk yard, ran the part number thorough BMW to get another one and got a different part. At some point in time they changed the part without changing the number.
                    You can also use one form an e12 528i with the 265, again if you can find one. This is a stamped steel mount that supports the transmission form the rear tab. The problem here is the rear tab will most likely be farther back then the available mounting rails on the car. I had to use this setup for a period of time and made rail extenders out of 90 degree angle iron, bolted to the car and then the mount. Not the ideal set up but it worked.
                    If you have the money the M3 mount is probably the easiest rout and best quality mount available. Is straddles the 265 supporting it on both sides and has 4 bolts attaching it to the car verses 2. Best of all there is no modification required it simply bolts right up. As it should considering it was designed to hold that transmission in that car.
                    If you’re low on cash and scrounging up parts to do the conversion try checking out the local junkyards… you might get lucky. Otherwise just try to source the M3 mount it’s really the best way to go.
