Trans Output Flange Swap
    Originally posted by Ian McClure View Post
    So what do you guys to about the vibration dampener? Do those need to be swapped too or do you guys just eliminate them completely?
    I eliminated mine.
      Eliminated also
        Next ...
        Are Three Vee
        Dad Spec
          The guibo was stretched a bit and I thought it would work itself out but it didn't. I moved the engine to the rear position and the driveshaft no longer fits. I had it shortened and it simply does not work. The pilot bushing bottoms out on the output shaft before the guibo can seat properly, causing it to flex no matter what. The output shaft on a 260/6 is tapered while the 260 is smooth. I thought made mine work by getting a custom guibo made by revshift that is 5mm thicker than a standard one, but it is just bending grade 8 bolts like it is nothing. Going to have to swap big flange back and run an E28 front with the big guibo. Just want to save the headache/money for others.
          Are Three Vee
          Dad Spec
            Why not just use the 260/6?
            The 260/6 is an upgraded, stronger 260/5. BMW switched from the 260/5 to the 260/6 on the m30 cars for a reason.
            Zinno '89 <24v swap in progress>
              I am using a 260/6 ... I tried to swap the flange to the smaller to use my stock driveshaft. 260 was in reference to the M20 trans.
              Are Three Vee
              Dad Spec
                Ah ok I need to read better:)
                  sorry i didnt see this before you started. if you switch the to the smaller flange you have to shorten the output shaft on the transmission but it will allow you to use the stock 325 ds. I did this on mine and it still runs fine. wayyy easier than a custom driveshaft.
                    I had the same problem (except was with a G265) I ended up spacing the motor up and bringing the transmission down to mate directly, ie: without flex, to the guibo. (I made my own engine mounts and modified the transmission cross member myself)
                    You want no flex OR stretch whatsoever on those things otherwise you will chew through them like crazy!
                    I also just had the large guibo flange welded onto my e30 tailshaft (also had it shortened at the same time) thing fit perfectly.
                    ///Monstrosity. (OO≡≡[][]≡≡OO)
                    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                      Old thread but I'll add to it anyway.
                      I also swaped flanges on my 260/6 and encountered the problem of the larger output shaft interfering with the driveshaft. I solved the problem by simply drilling a hole inside the front half of the stock 325i driveshaft with a 5/8" drill bit to make some room for the output shaft. The guibo now slides easily all the way against the output flange.
                      I miss the old BMW
