Difference between getrag 280 and 260/6?
  • ttrousdell
    • Nov 2009
    • 1770
    Im going to check out a s38b36 tomorrow and the guy selling wants 1k extra for the 280 tranny. Are the benefits of this tranny worth its price tag. Id imagine its more robust then the m30b35 tranny. Keep in mind that i would couple my 260/6 from my m30 swap with the s38 if I didnt end up purchasing the tranny. Input please.
    The Build:
  • Eric
    • 5141
    I'm not a huge transmission guy, but from what I know is that the G280 can handle more power than the G265 (not sure about G260/6) but are expensive to rebuild and less plentiful than the G265. MyE28 has a few guys that swap the G280 out for a G265 including a write-up on it.
    • ttrousdell
      • Nov 2009
      • 1770
      I guess i could consider that option if it was necessary. http://www.mye28.com/viewtopic.php?p=973324 I would like to not have to buy a new tranny though. From what i've read the 260/6 bolts right up to the s38.
      G260 e34 have these ratio ....
      1=3.83 2=2.20 3=1.40 4=1.00 5=0.81
      the G280 is a bit little longer so ,, either another driveshaft .. or shorten the one under the car
      G280 ratio ... 1=3.53 // 2=2.08 // 3=1.35 // 4=1.00 // 5=0.81
      you can see that 1st and 2nd are just a margin longer,, on the G280 and with 600+ revs on the S38 vs M30B35 this would give a good accleration from 0standstill or 10mph rollin start
      this is a bolt on
      The Build:
      • Eric
        • 5141
        I feel that the jump for 2nd to 3rd is too spaced apart on my E28M5, now on my old E34 M5 with the 3.8L and the same G280, it was a better match.
        • yert315
          • 2734
          for $1k? Not worth it at all. Guys are pushing 4-500hp on the g260 and g265 without breaking a sweat. Those transmissions are plenty strong enough to handle s38 power.
          • Lurker27
            • 821
            You'll break the E30 halfshafts before you break the 5 series driveline components
            '89 335is +turbo
            • Doughnut
              • Oct 2007
              • 869
              I had a g265 in my m30 e30.
              It was a great transmission, plenty tough enough, only problem was that it leaked oil from in between the case sections.
              ///Monstrosity. (OO≡≡[][]≡≡OO)
              Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
