Ok so I finally got my oil temp/pressure gauges installed and have a couple of questions about my readings. The PO installed the oil pressure sender on the back of the cylinder head next to the firewall; I don't know much about the M30 oiling system and am wondering if this is an o-k position for it. At idle I am reading about 2 bars of pressure, cruising around at about 2750 RPM I am at around 4 bars, give or take. I am just curious if this would be an accurate reading as the pressure sensor is so far from the oil pump...
Also, even after driving for 30+ mins my oil temps never seem to get above 70ish deg Celsius, it usually sits around 60ish C...which seems a bit cool to me. I am running the M30 oil cooler, but I didn't think it would drop the temp that much. What is normal op temp for oil, and is my temp being so low detrimental to anything?
