old block
  • turnofftheradio
    • Apr 2005
    • 448
    old block
    The fellow I got my 325e from has the old block laying outside his garage, It has sat for 2 or so years, open ie. no head,crank,bearings. the cam and pistons are still there. the engine looks terrible from sitting out. As far as he and I know, there are no cracks in the block. He dropped a valve while driving, that killed the engine. I guess what I want to know is...
    Are the bearing seating surfaces going to be destroyed from rust?
    I know a guy who can bore the block out for a great price (free) and since my block has a broken ear where the alt/ps pump bolts on, I have been searching for an alternative.
    What else should I check out? the cyllander walls are rusty, but do not look hacked up the valve just sort of imbedded into the piston.
    If this is not a viable option no big loss, I can get another block from the yard cheaply that is intact and sealed. but free is usually better whenever possible...
    advice? use the crusty block or just get a used block from the yard?
  • Addissimo
    • Mar 2004
    • 1820
    If its free, just take it and open it up, its the only way to tell for sure.
    I'd guess that the engine internals would be fine (aside from pistons).
    Hopefully the rust isnt too deep into the cylinder walls.
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • turnofftheradio
      • Apr 2005
      • 448
      If I run a honer through the cyllanders, I should be able to tell from there if they are too far gone? I would hate to waste the time of boring it to find out that it is no good.
      the oil pan is off too. everything is rusty and snow covered at the moment...
      what really gets me is that it is the origional engine, and to me that is special, to an extent.
      • turnofftheradio
        • Apr 2005
        • 448
        I found an ugly gouge on the cyllander wall :( no block for me.
