That was my biggest fear too, but thanks to these other guys for the info and help, not me.
'89 325i + m30 + 4hp22 build
Streetable poly mounts, trans mounts are here!
http://www.r3vlimited.com/board/show...ght=streetable
'94 318i
'07 335i
'11 X5
'89 325ic m30b35 -
It's way too loud to drive at 4 am to work, hopefully the resonators will help with that... Once I get all the cooling kinks worked out I'll get some better footage...
E30 M30B35 automatic: http://youtu.be/9WXEQybLbcE
M30B35 E30 Borla muffler: http://youtu.be/kGJOXN2g6Yosigpic
'94 318i
'07 335i
'11 X5
'89 325ic m30b35Comment
Well fellers, I'm about to take on the same deal. I got a m30 and a 4hp22, but mine is the electronic one. I'd love to try to get it to work as it was intended. From what I've read, it would be a sport/economy switch and some other bits. My m30 came with the auto harness and ecu and the trans came with its harness and ecu so it should be relatively cut and dried, right? What are the best resources for m30 and 4hp-22 transmission reading? Good read guys!Last edited by Ether-D; 07-08-2014, 10:52 AM.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
From what I remember, if you have that trans harness then yes you should be alright... I have a few of the switches for economy and sport as well as a gear selector cover from a 5 series with eh... Pm me your info and I'll send them so you can see if they'll be of any use...
I just remembered something else, there was a plug for the dash that shows the gear it's in (digital) but maybe you can just bypass that option... May have had something to do with speedo and rpms too, don't recall... Also, the output may be different from your e30 driveshaft.sigpic
'94 318i
'07 335i
'11 X5
I'll see if I still have the literature bookmarked next chance I get...sigpic
'94 318i
'07 335i
'11 X5
Thank you sir.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
New plugs and fresh gas (the other stuff was a yr and half old lol) enjoy!
'94 318i
'07 335i
'11 X5
'94 318i
'07 335i
'11 X5
Supercharge it! That's half the reason I wanted a m30 swap, to build a supercharger for it. TORQUES!Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
