e34 transmission for my m30
    My 260/6 has a broken tab and while looking for a new tranny found this e34 525i part out on craiglist, what tranny's did this car come with? Need a direct replacement.
    Cheers.
    It is going to be an M20 trans so Getrag 260 which won't work. I would personally have the tab tig welded back assuming the rest of the trans is good.
    Are Three Vee
    Dad Spec
      thanks for the heads up. Unfortunately the tab is long gone...
        That sucks man :/ I am sure someone could fab something up for you though.
        Are Three Vee
        Dad Spec
          Had a broken mounting tab on my m30 tranny, tab was completely gone. Had a local guy weld one up for me. Super easy fix for someone with the ability and equipment to weld aluminum.
            aight, my shop wasn't sure if their new welder was strong enough. but I'll look around. How much it put you back?
              I had a broken tab on my 260/6. Had a friend weld it with a mirror while installed! It can be done.
              1987 325i-M60b44 swap
                my trans is no bueno overall
                anybody know what this car might have for a tranny?
                http://portland.craigslist.org/mlt/ptd/3817500028.html
                  it wont be the right tranny for the m30. If youre in a pinch, you can use the m10 getrag 240 trans but then youd have to change your clutch as well.
                  Taylor
                    The tranmission has to come from an m10, m30, s14, s38, and i believe m88 and m90.
                    Find a car with one of those engines, and the transmission will bolt up. Though your clutch, shifter, and driveshaft may not
                    1991 335is in progress
                      A tab is broken on my trans drilled holes futher up the trans, and made a custom mount
