m30 idles at 1000 rpm
  • clementine
    • 20
    just wondering if its normal for the motor to idle at that rpm.
    help is appreciated
  • kronus
    • Apr 2008
    • 13032
    It's not. You might have a vacuum leak, inspect your various boots and rubber things for cracks.
    cars beep boop
    • yert315
      • 2734
      ^ check what Kronus said first. If you have 100% confirmed no vacuum leaks, check your ICV.
      • clementine
        • 20
        will do thanks guys.
        • Vivek
          attention whore/retard/bitch
          • 6167
          Smoke test it. You may not necessarily see a crack that could cause a vac leak.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • aje28
            • 572
            Make sure your TPS is adjusted correctly, usually an m30 should be around 750 +/- on idle.
            • clementine
              • 20
              i think i found the problem.
              since i swapped the motor into a 318 i must change my decoding plug on the cluster, so by changing it, it should now show the proper idle,
              so pretty much i was fooled by my own car
              lol
              thanks for all the help i might need it in the future
