M30b35 vacuum lines
  • Norma
    • Feb 2013
    • 11
    M30b35 vacuum lines
    I just changed the head gasket on my 89 735i motor and I have everything hooked back up but the intake. (To my assumption) my stall is vacuum lines...
    I have no pictures currently but I could take some if needed. Anyone have a vacuum routing guide for this motor?!
    :early:
  • JoeMadoo
    • 936
    The vacuum setup is pretty simple on the m30 compared to other motors. You could always go to a junkyard to look at someone elses setup.
    Searched "m30 vacuum diagram" in google and found this.
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
    • chance
      • Feb 2012
      • 671
      I did not install the charcoal canister, and I also ran the fpr straight to the valve cover hose tee and capped the ports on the bottom of the intake.
      Am I going to have any problems doing this or do I need to run vacuum lines to the bottom of the inake and back to the tee.
      1991 335is in progress
      • uturn
        • Dec 2010
        • 998
        The FPR works under vacuum. Your current setup, that tee gets nothing but positive pressure coming from the crankcase.
