Starter replacment on a e30m30
  • george graves
    • 19996
    What a pain in the butt - I spend two hours trying to reach the upper bolt on the starter.
    My motor is a m30b35 - but it left the factory with the older type starter - the larger, heaver, and less TQ version(1.5K vs 1.7k), that has
    pockets for the bolts - meaning you cant get a socket on it.
    Just a tip to anyone doing an m30 swap - upgrade your starter to the newer 1.7k smaller, lighter (by 10 pounds) higher TQ starter before you swap.
    I'm going to pull the intake manifold - that should take 30-40mins....and make it easy as pie.
    Originally posted by Matt-B
  • F34R
    sLaughter
    • 12376
    Still much faster than an m20.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • wildstoats
      • Sep 2007
      • 896
      I ran into the same problem with mine so I ended up replacing the stock bolts with socket heads just in case I need to take it off again.
      • chance
        • Feb 2012
        • 671
        Fack I wish I would have known that before my swap.
        I've got the old huge one apparently. The unloader is toast, hopefully the starter lasts.
        1991 335is in progress
        • Jean
          • 18228
          Smaller starter FTW... oh, on the v8 it's on the bottom ! :)
          • Doughnut
            • Oct 2007
            • 869
            You big wuss!!!
            Crack the bolt with your 17mm ring spanner and undo with fingers.
            :p.
            ///Monstrosity. (OO≡≡[][]≡≡OO)
            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
            • george graves
              • 19996
              Originally posted by Doughnut
              You big wuss!!!
              Lol - who you callin' a wuss, wuss?
              No really, I can't even see the bolt. My motor is too far back - the bolt is about in the tranny tunnel almost.. I could get it to it with a stubby closed end, but you can't get it to budge with a 3-4" wrench. Above it is the mani, below is he starter, and next to it is the booster. It's a no-go.....
              I don't care - I haven't dug into the motor since I installed it - so it will be good to look around and make sure everything is ok.
              • reelizmpro
                • 9511
                Interesting. I just ordered an SR441x high torque starter for my M3 for $100. Figured I'd give it a shot. Hopefully it lasts as long if not longer than the original.
                88 M3 - LACHSSILBER/SCHWARZE
                • Doughnut
                  • Oct 2007
                  • 869
                  Hahaha!
                  Just be prepared to replace the inlet manifold gaskets if you remove it, they often tear.
                  Enjoy!
                  • george graves
                    • 19996
                    Well, I started off the day getting ready to remove the intake manifold. Thought it would take an hour tops....boy was I wrong...
                    Got all the top bolts off with out pulling the fuel rail/injectors(I have the M30b35 plastic rail cover - so it make is hard to do). That was a pain - no room to work. The m20 is so mush easier. Anyways...Then got number 1, 2,3 lower bolts off.
                    Then I realized that I'd never get to the bottom #6 bolt off - the starter is in the way. (I think I need to invest in a set of warbles actually - I lost mine - must move forward and get-er-done)
                    So....
                    I can't remove the starter, cause manifold is in the way....and...
                    I can't remove the manifold, cause the starter is in the way......
                    Damn you M30 swap!!!!!!.....And yes, I was complaining like a schoolgirl the whole time....
                    I ended up grinding down a 17mm socket to more or less 1/2 it's size and rounding it's profile down to that it would fit the "pocket" of the starter. That worked - but I had to remove all the cooling hoses to make room. I did the top bolt first - and it got bound up as it was getting backed out - the modified socket was hitting the starter's pocket. So in my frustration I just powered it home with a an impact gun - drilling out a chunk of the bad starter. Whoops. (who cares - it worked)
                    If I was smart - I would have done the bottom bolt first and then it wouldn't have bound up. Oh well.
                    The new starter is in - so much easier - took 10 mins, and it cranks....
                    And just FYI - meh....I'm not all that impressed with the upgraded starter. It doesn't sling the motor over any faster - if anything it does it smoother - and more gradual. But the old large starter would start the motor with a 1/2 a revolution of the motor. New one seems to ramp up it's speed and need a full rotation of the crank to fire up the car.
                    Old = "chaaaa....purrrrrrrrrr"
                    Upgraded"chaaa-ca-caaaaaaaaaa.....purrrrrrrr"
                    Starting sound much more like a newer car. Where as with the old one it had that old-school BMW sound. Not sure I really care that much about how it sounds. Just FYI.
                    • 603Racing
                      • Dec 2010
                      • 612
                      Thanks for the heads up. M30b35 still on the engine stand. I did notice that the top starter bolt looked like a PITA.
                      90 325i DD/Track
                      03 Durango 5.9
                      Originally posted by e30mpg
                      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                      • rav320uk
                        • Jun 2004
                        • 1337
                        There's a trick to taking the starter off in the E30 bay.
                        You need a stubby spanner, ring one end.
                        Feed a strong rope end through the ring end and feed it up through the firewall and mainfold.
                        Holding the rope above, and this is for the top bolt, put the spanner onto the bolt.
                        Now you have leverage ontop to undo the starter bolt.
                        That's how I've done mine in the past.
                        HTH's
                        If you have bought items from me, please leave feedback below.
                        If you are a BUYER, Check My Feedback.:up:
                        http://www.r3vlimited.com/board/showthread.php?t=183860
                        Check out my Euro Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=215557
                        • homegrone30
                          • Jun 2007
                          • 1449
                          How do you figure? Get wrench and an impact with a long extension. Put the box end of the wrench on the trans side of the bolts through the engine compartment and hit the front with an impact. Don't forget to disconnect your battery.(I know no one here needs to be told that right?) I've done this several times. It should take a half hour tops.
                          Sent from my SPH-L710 using Tapatalk 2
                          • Doughnut
                            • Oct 2007
                            • 869
                            HTH's
                            Innovative!
                            Assuming your engine is as far back as George's (position 3-ish) There just isn't the room for this method, so much crap in the way!!
                            • bmwwheelman
                              • Dec 2010
                              • 15
                              Upgrade your m30 starter to the m70 starter.
