M30 modification plan
  • e30nerdy
    • Jul 2013
    • 6
    My budget is 3000$
    Also I possess a 1992 535i automatic motor from my brothers part out
    I have the parts needed for manual conversion
    and I am more about the necessities than "while i'm in there let me do this"
    Here is what intrigued me:
    “Good'n'Tight was putting down north of 500 whp/wtq with a HX40 turbo on a standard m30 B34 bottom with not much done to it other than studs and a MLS head gasket.."
    Now, I was trolling among many threads I decided to compile a list to choose from.
    I. MLS head gasket (u can get thicker ones to lower CR a bit, your engine should be in the 8's already)
    ARP head stud kit
    GT35 or GT40 turbo. Something similar will do. HX40 turbo?
    External wastegate of some sort
    Custom made exhaust manifold
    II. Wilder or schrick camshaft with steel rockers adapted with KKK Turbo Manifold or M5 intake manifold or TCD RHD Manifold
    III. After market stand alone ECU
    IV. as for the Intercooler system, ill probably go with an "Air/Air"? and SQUEEZE it behind the kidneys
    please dont hate me for sounding like a moron ;) just inform me instead
  • Bimmer_man
    • Jan 2013
    • 1477
    So you have $3000 for everything listed ? if thats the case your going to spend about half of that at least picking up then engine and rebuilding it so its ready for a turbo. At the vary least. And S38 parts cost a little more than a pretty penny. the crank alone ive seen anywhere from 600-800.
    Float like a cadillac sting like a Bimmer!:)
    • e30nerdy
      • Jul 2013
      • 6
      Titan..sorry let me clarify I have the motor already.I dont really feel the necessity to rebuild if its not that bad. Just a port and polish maybe.
      • Bimmer_man
        • Jan 2013
        • 1477
        alright just take note that the engine you have was not built to take a turbo so just be warned. Lack of proper hardware and you will destroy that engine. My brother did that to his car and destroyed the engine.
        I will say good luck though man. at least have the pistons,rods, and crank checked.
        • e30nerdy
          • Jul 2013
          • 6
          thanks man much appreciated
          • Herr Faust Schinken
            • Feb 2012
            • 3580
            Rods are very strong on m30s, pistons too, I wouldn't worry about a s38 crank. Do new main and rod bearings Arp head studs. Vac makes a turbo cam for m30s that's supposed to be good, do IE heavy duty rockers, make sure the valve springs and valve seals are good, make the motor reliable then boost the crap out it
            88 325is Five Speed
            Lachssilber
            • e30nerdy
              • Jul 2013
              • 6
              Schinken,thanks for the input right now I am still "trolling" using the search function using the word "budget" lol my main goal is to do it cheaply and reliably.
              • Good & Tight
                • Apr 2004
                • 2057
                Didn't see clutch on your list of things to buy. You will deff need a strong clutch to handle the torque.
                Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                ____________________________
                E-mail Panayiotisx2@gmail.com
                Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                • e30nerdy
                  • Jul 2013
                  • 6
                  Good & tight, your the man thanks for the inspiration. So what exactly did you really do part wise for your swap. Did you really not use that many parts?
                  • yert315
                    • 2734
                    slap the engine in with a proper clutch and turbo. Then TUNE. tune tune tune. There are plenty of stock b35s running boost reliably. I can't stress enough the importance of a tune. This is where 90% of the reliability for a turbo system comes from.
                    I'm sure I'll get flack for this, but don't worry about cam, bearings, head studs, etc. The b35 is a bullet proof engine. You'll make plenty of power with the stock setup. I would only change the timing chain guide rail and tensioner rail.
                    • Good & Tight
                      • Apr 2004
                      • 2057
                      I fabricated everything, manifold, exhaust, intercooler piping, engine mounts..list goes on. Engine wise, stock bottom end B34, B34 head with Schrick cam, ARP's, Cometic gasket stock thickness.
                      And like yert315 said, tune tune and tune, it really is the most important aspect of turbo system.
                      • e30nerdy
                        • Jul 2013
                        • 6
                        Thanks for the info Tight and Yert, you guys are of much great help.
                        • kylelauffer
                          • Dec 2009
                          • 624
                          its an m30 for crying out loud.studs b34 bottom end metal headgasket. and boost it. right now i am realiable as hell at this power. and yes do all seals while the motors out. spec clutches are not too bad. these motors are bad ass. and if it ever goes pop its 300$ and a little elbow grease to get another one in. lol
                          • Lurker27
                            • 821
                            Find my build thread. It's exactly what you're trying to do.
                            '89 335is +turbo
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              Thought you were running an M90 head? and thus the early style distributor?
                              This with a B35 head slapped on it /done.
                              M30 is IMO about the best engine BMW ever made. Simple, and can handle A LOT of abuse. I drove one around with a severely cracked head (between cyl 5/6 and 3/4) and blown HG. It simply didn't care, kept going.
