Been scoping around here for a while had a good search but cant find exactly what i need to know.
I have a M50B25 non vanos.
Firstly id like to increase the capactity then possibly turbo it.
1. Can i use the m50 pistons and rods(forged?) with a m54b30 crank?
2. Can i use M50 pistons and rods with m52b28 crank?
3. if not whats the best setup and why? id imagine forged internals is the way forward with the possibilty of turboing.
4. What compression ratios am i looking at with the above combinations? and are they safe for turboing with or would i use a different headgasket to lower compression ratios?
5. Management. Would a stroked engine run on the standard ecu or do i need a standalone unit?
Thanks in advance.
Thanks in advance.
