i'm going to be doing my rear suspension this upcoming weekend, i can measure and post my setup with 240 and cut driveshaft
The m30 with Getrag 240 thread
This is a sticky topic.
Originally posted by glnr13 View Posti'm going to be doing my rear suspension this upcoming weekend, i can measure and post my setup with 240 and cut driveshaftSi vis pacem, para bellum.
New Hawtness: 1995 540i/6 Claptrap
Defunct too: Cirrusblau m30 Project
Defunct (sold): Alta Vista
79 Bronco SHTF Build
Was wondering if anyone has any experience with the setup I plan on using.
-84 318i g240
-m20 flywheel
-m50 clutch
-e30 318is shift linkage, driveshaft and trans bracket.
What throwout bearing do I need? Can I use the 318is mount bracket and shifter??= Heidi 1988 325 -> 335i. 7200rpm built M30
M20 flywheel will not work. It has a the wrong number of teeth on it and will cause starter interference.
Edit: If you want to run a 228mm flywheel you need a 228mm flywheel off a 2002tii m10 motor.
Or you can use the complete M10 240 set up with an uprated clutch.Si vis pacem, para bellum.
Originally posted by marshallnoise View PostM20 flywheel will not work. It has a the wrong number of teeth on it and will cause starter interference.
Or you can use the complete M10 240 set up with an uprated clutch.= Heidi 1988 325 -> 335i. 7200rpm built M30
Originally posted by totheredline View PostSo I couldn't use an m50/m20 starter?
Originally posted by totheredline View PostMaybe use a different ring gear?Si vis pacem, para bellum.
So, I test fit a 1997 318ti manual driveshaft with my b35 in pos 3, it was a 1/4 inch off at most for a perfect fit. So I took the plastic compression bushing out and cut it in half with a band saw. I put the bushing back on, only smaller this time, and it fits. It's a damn tight fit, but it works. I think once I re thread the end of the shaft for the nut, it will work.
Pics up soon.
Originally posted by SketchyRex View PostSo, I test fit a 1997 318ti manual driveshaft with my b35 in pos 3, it was a 1/4 inch off at most for a perfect fit. So I took the plastic compression bushing out and cut it in half with a band saw. I put the bushing back on, only smaller this time, and it fits. It's a damn tight fit, but it works. I think once I re thread the end of the shaft for the nut, it will work.
Pics up soon.Si vis pacem, para bellum.
Originally posted by SketchyRex View PostYeah, test drove the beast last night. Driveline felt good and preformed great. Only time will tell whether its durable enough or not.
It won't let me upload my pics from my iPhone. Do I need to put them on photobucket or tiny pic or something?Si vis pacem, para bellum.
