Anyone got an extra m30b35 oil pan they're willing to sell? A curb decided that mine wasn't worth having.
The m30 with Getrag 240 thread
This is a sticky topic.
Got my hands on a 1984 318i parts car. I'm going to be using the transmission and flywheel from that car. What clutch should I use? I don't want to spend a whole lot on a clutch setup because I'll probably be moving to a G260 after this summer. Can I use a clutch from an m42 car on an m10 flywheel? They're both 215mm clutches. The reason I ask is because I can get a performance clutch for an m42 for a lot less than I can get one for an m10 car.= Heidi 1988 325 -> 335i. 7200rpm built M30Comment
This is for an m10 and it's only $160 with pressure plate.
It's what I'm likely gonna use.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Nice find. I'll probably go with that one too! I actually have an fx stage 2 clutch in my 22re toy pickup and its held up fine.= Heidi 1988 325 -> 335i. 7200rpm built M30Comment
Ended up going with that clutch. The pressure plate is actually a sachs and the friction disc is a gripforce. Seems to be pretty good quality!This is for an m10 and it's only $160 with pressure plate.
It's what I'm likely gonna use.= Heidi 1988 325 -> 335i. 7200rpm built M30Comment
Nice! Please report back in here with your opinion of it when it's up and running.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
Why poor buggers? My Getrag 260 + single mass flywheel & 240mm clutch kit are still sitting on a shelf in my shed - the G240 & 215mm clutch has lasted more than 3 years in my car and is showing no ill effects having been daily driven that whole time.
I'm starting to think that if you get hold of a good gearbox to start with that the G240 won't break with a stockish M30B35 in a street car.Comment
I agree, I heard mixed reviews on the g240 behind a 3.5, and although my swap has only been running for the last 4-5 months, I have beat the living shit out of this thing to see what it can take. I have nothing but faith in my setup. The g240 is a good starting point.Comment
That's what I am gambling on.Si vis pacem, para bellum.
New Hawtness: 1995 540i/6 Claptrap
Defunct too: Cirrusblau m30 Project
Defunct (sold): Alta Vista
79 Bronco SHTF BuildComment
I had heard somewhere awhile ago that the most Torque you can put through these is like 260ft lbs. I guess if a dude just wanted to have a fun m30 with a light setup, the 240 is the way to go. If you are going for big power I doubt the 240 would hold.Comment
Just out of curiosity, how much should it cost to have the front section on my 318is driveshaft shortened and rebalanced?= Heidi 1988 325 -> 335i. 7200rpm built M30Comment
