m30b35 swap e30, harness?
  • willy-guldager
    • Dec 2012
    • 23
    So i need a new harness for my m30b35, and ive heard you can use a harness from a 325? Right now i have a harness from a 323i? Does anyone know if i can use that harness?
  • E30_fiend
    • Apr 2006
    • 7348
    Nope. It's needs to be a late model 325i harness. They are both Motronic 1.3 which is what you need.
    Taylor
    • tfritz
      • Jan 2008
      • 590
      I would personally use an m30b35 harness. Though it is said that the late model 325i harness will work, I had issues using that harness and went to the m30 harness with no problems.
      • slammin.e28
        שמע ישראל
        • 12054
        1987 325i harness works great, the ECU connector is correct, and the injector plugs aren't encased in a plastic housing.
        Later 325i ones will work, but you'll have to take the injector plug housing apart.
        I'd just get an M30B35 harness and be done with it. Everything will be proper and the injector wires will be in the housing as god intended.
        • marshallnoise
          • Sep 2013
          • 3148
          +1
          Not that I have a running b35 right now, but if you have to replace the harness anyway, might as well be the one the engine expects to use.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • E30_fiend
            • Apr 2006
            • 7348
            The only way I would use the b35 harness is if the injector connections are changed to the tab style connectors. The b35 connectors are bullshit.
            Taylor
            • F34R
              sLaughter
              • 12376
              I know a friend that used the b25 harness without any issues. It can be done, but the b35 harness is best if you have it.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • csermonet47
                • Jul 2009
                • 937
                I don't know why everyone keep saying the B35 harness is the best. The B25 harness is the best. Period. People that say otherwise do not know what they are talking about. There is no advantage to running a B35 harness and the engine doesn't "expect" a B35 harness, it expects a Motronic 1.3 harness. It could care less what car it goes to.
                All it takes is little thinking and you make the B35 harness box work with the B25 harness. You literally have to lengthen 1 wire, removing some plastic, and rewrap the harness to make it work and it is 100% cleaner than using a B35 harness. It already fits the E30 engine bay and everything works like factory. No check engine lights or anything. C101 plugs right up and you're good to go.
                Do what you want to do, but the M20 harness is without a doubt the cleanest way to do it.
                Are Three Vee
                Dad Spec
                • LJ851
                  • 7919
                  Sez Mr. Clean.
                  Lorin
                  The M30 is God's engine.
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    I was waiting for Ryan to get in here.
                    Taylor
                    • Jb325is
                      • 2137
                      Yeah the b35 harness kind of fits terrible in the e30. e34 ecu's are in the engine bay, e30 is in the glove box, so the b35 harness is not long enough. I was trying to think of some reasons to go with the b35 harness while I was writing this but I couldn't.
                      - '88 m54 coupe
                      <3
                      • navytapaul
                        • 615
                        I agree, I had to mount my ecu backwards just to get the harness to connect. Would have much rather gone with an i harness and the b35 plastics for aesthetics. Like it was said earlier, only 1.3 needs to be seen, harness doesn't really matter. I would rather have a harness that fits and doesn't have all the extra connectors my e32 harness has...
                        • G-Man the Visionary
                          • Apr 2013
                          • 543
                          Did your B25 harness come with that TPS?
                          I've had my engine running (turned on/ idle) on the B25 harness (swapped TPS sensor), but didn't have a few plugs hooked up that wouldn't reach... While at the junk yard the other day, decided to grab a B35 harness... What mods would be necessary to run B35? I believe the C101 plug is the same, round...
                          Thanks
                          BTW, clean car... Hope to get there...
                          Streetable poly mounts, trans mounts are here!
                          http://www.r3vlimited.com/board/show...ght=streetable
                          '94 318i
                          '07 335i
                          '11 X5
                          '89 325ic m30b35
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            If you already have a M20 harness, then just unwrap it, plug all the plugs in on the engine and re-wrap it. Lengthen a couple of injector wires & fit the M20 injector loom into the M30 plastic box and you're done.
                            I did my swap this way & it is a lot neater than my friend's car who is running the M30 engine loom (for the reasons already mentioned).
                            My e30: OEM+ with M30B35
                            • F34R
                              sLaughter
                              • 12376
                              Completely forgot the m20 harness is longer. I got lucky and did not have to cut any wires to run my b35. Came from factory all ready to fire and run perfect.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
