m30b35 swap e30, harness?
  • george graves
    • 19996
    I believe you need a 1.1 or 1.3 harness. I used the harness original to my car. A '89 325is. A 1.1 and 1.3 harness should be pin identical. The only difference was interal to the ECU. But don't quote me on that.
    Originally posted by Matt-B
    • Mr. Burns
      • Aug 2011
      • 3516
      Bumping this up from 2 years ago.
      2nd time I deal with this.
      E30 body harness plus is female end
      M20b25 wire harness C101 plug is male end.
      M30b35 wire harness is female.
      Wtf.
      Originally posted by flyboyx
      i have watched my dog lick himself off a few times
      • Coupelx
        • Oct 2013
        • 169
        Wtf.
        no different then a 24v swap then, buy or salvage the needed c101 connector and purchase the pins from your favorite bmw parts place. there are 3 different pins depending on wire size although the actual pin end is the same.
        • lukeADE335i
          • Apr 2013
          • 1385
          Or as most of us suggested previously - dump the B35 harness and use the M20 harness :)
          Easy to do & fits the e30 engine bay perfectly (and then you can run the e30 M3 wiring covers to look totally factory)
          My e30: OEM+ with M30B35
