b35 runs but hard starts
  • navytapaul
    • 615
    Just started doing this in the last week. It takes for ever to start but runs just fine once it does. I've checked all fuses, the e32 harness, and I have fuel since it runs fine. Am I not checking something obvious or did I miss something?
  • Doughnut
    • Oct 2007
    • 869
    Is the fuel pressure regulator serviceable?
    Check fuel pressure at ignition 'on' before cranking, you could have an issue with a tired fuel pump and check valve.
    Double check fuel filter.
    Did you have issues with the original motor?
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
    • navytapaul
      • 615
      No, it started just fine before my swap and I put a new filter in last year.
      Sent from my SAMSUNG-SGH-I727 using Tapatalk
      • LowR3V'in
        • 4209
        Dieing battery.
        Every single start?
        • marshallnoise
          • Sep 2013
          • 3148
          Did you have the head off the car at all? Me thinks timing could be a cause of hard start. If the chain is off a cog or two it might be problematic.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • kronus
            • Apr 2008
            • 13032
            I've had a similar problem with a failing check valve in the fuel pump. If the rail isn't under enough pressure, it won't be able to supply enough fuel to start for a decent bit of time.
            Timing would not make for hard starts, it would make for bad running.
            cars beep boop
            • navytapaul
              • 615
              no it's not every start, and I had the head off when i rebuilt it months ago. This didn't start happening until about a week ago, and it's sporadic now. Kronus, I'm thinking you might be right about the fuel pump as it's the only part I haven't replaced and very well could be starting to go. I park on a decline in front of my house, and it does it 85% of the time then, but when it's on flat ground it starts right up...weird.
              • Doughnut
                • Oct 2007
                • 869
                Put a gauge on the fuel line to check fuel pressure, It will prove the pump and check valve straight away.
                • LowR3V'in
                  • 4209
                  Mine goes to 0psi after sitting but still starts up good.
                  • Yakinho
                    • Feb 2007
                    • 650
                    Cold start valve? Mine broke at the hookup on an older m30 and took 20+ cranks to start. Did that for a week, then it magically decided to work.
                    • navytapaul
                      • 615
                      B35 doesn't have a cold start valve
                      • navytapaul
                        • 615
                        So when I unplug the AFM it starts right up, does that mean its going bad or just need to be cleaned? I cleaned the plug and connection with some CRC so hopefully that helps.
                        • Doughnut
                          • Oct 2007
                          • 869
                          Yes.
                          Check fuel crank pressure with ignition 'on' (fuel system is primed ready for start)
                          • navytapaul
                            • 615
                            I have an early eta so the fuel pump doesn't prime in the on position.
                            • navytapaul
                              • 615
                              I checked the resistance on the cps yesterday and it was way off. It measured ~1350 at 40° F, but I'm not sure how that translates when it's supposed to be between 490 and 590 at 68°F. I cleaned a bunch of grime off of it too and now it starts a lot better. I guess that was the problem?
