Replicate m30b35 in Alpina/Hartge
  • E30335i
    • Feb 2014
    • 1035
    If you look at the figures that Alpina/Hartge makes from that engine, it's pretty amazing at 261hp and 346nm Torque. I've contacted both companies and only way I can get replacement parts or more info is if I actually own one. But I do not so they cannot give any more info on it. I know I can turbo it instead but I read posts of people attempting to make na power and it's almost close but not enough. I just haven't seen anyone on the forum make a post about it so here I am doing it.
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Lookup the username Japandrew73.
    • kronus
      • Apr 2008
      • 13032
      high compression pistons, aggressive cam, hours and hours of flow bench work will put you there.
      cars beep boop
      • wildstoats
        • Sep 2007
        • 896
        http://www.m535i.org/officers/ra/article.html#motor
        • e30m3s54turbo
          • Jun 2010
          • 3276
          Alpina B6 3.5 e30 261hp.
          Alpina cam
          Alpina 2mm larger valves
          Alpina headers
          Ported and polished head
          High CP
          Hartge H35 1984-87 250hp
          H35 1988-91 240hp
          Hartge cam
          Hartge 2mm larger valves
          Hartge headers
          Extreme ported and polished
          High CP.
          I do own a m30 Hartge head. My friend Frank owns a Hartge H35 m30 b34 motor.
          • LJ851
            • 7919
            Don't leave out Schnitzer and their 3.7L @ 275 hp.
            Lorin
            The M30 is God's engine.
            • Bearmw
              • 1323
              And now we have better coating technology and engine control systems. Attention to detail will get you there.
              • marshallnoise
                • Sep 2013
                • 3148
                I can't imagine it is worth it. Cost benefit is brutal. Cool factor of course. But lots of cash spent to be cool.
                Sent from my SPH-L710 using Tapatalk
                Si vis pacem, para bellum.
                New Hawtness: 1995 540i/6 Claptrap
                Defunct too: Cirrusblau m30 Project
                Defunct (sold): Alta Vista
                79 Bronco SHTF Build
                • e30m3s54turbo
                  • Jun 2010
                  • 3276
                  [QUOTE=LJ851;4035599]Don't leave out Schnitzer and their 3.7L @ 275 hp.
                  Lorin, I didn't for get about the AC Schnitzer 3.7. It is one of my favorite tuner motor.
                  • Bearmw
                    • 1323
                    Cost/benefit = chip and gear change
                    I spent under $1750 shipped on new custom pistons, and ported head/cam combo (which was an awesome deal). Another $ 450 on block magnaflux, boring, decking, cleaning and assembling my new pistons to the rods. Bearings, gaskets, timing chain, and miscellaneous engine hardware was probably another $400. My oil pump is not new but has good pressure.
                    Then there is the cost of a new clutch, hoses, exhaust... It all adds up but in my case I have a motor that should last for 200K plus with proper maintenance.
                    • uturn
                      • Dec 2010
                      • 1004
                      I just tried to order the Alpina headers last week. It's a two piece set. One piece is NLA and they wanted a VIN before they would sell the other. I'm a sad panda :(
                      • e30m3s54turbo
                        • Jun 2010
                        • 3276
                        Try ebay Germany. Some time they come up for sale between 300-550 euros.
                        • Bearmw
                          • 1323
                          FWIW the closer you want it to replicate an original Hartge, Schnitzer, or Alpina the more it will cost. Period correct is cool but expensive.
                          • navytapaul
                            • 615
                            One would think they could be replicated with todays technology and aftermarket. Parts are still expensive though
                            Sent from my SAMSUNG-SM-T217A using Tapatalk
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              Here, buy the whole car. It will be cheaper.
                              Originally posted by codyep3
                              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                              2001 silver/Blk 325 cabby. SOLD
                              2002 325xit Sil/blk. SOLD
                              2010 F650gs twin
