Should I boost an M30 or M50?
  • makeshift
    • Feb 2013
    • 131
    My m20 blew in the last 300 miles of a 2000 mile road trip a couple weeks ago. I've been weighing the pros and cons of different engine swaps since. I know I want another BMW inline 6 motor for simplicity and so I have space for a turbo.
    The question is, which engine should I get? I think Im leaning towards an m30.
    I love the sound of mid range torque in the 3.5L, and I was thinking that a turbo would make up for the lack power in the higher rpms.
    Also, the more modern DOHC 24v m50 scares me a little bit, it sounds like more to potentially go wrong when I add forced induction.
    Are these assumptions accurate?
    TIA
    Edit: By the way, I want to build a reliable DD anywhere in the range of 200-300 hp and 10-15 psi
  • Ether-D
    • Sep 2011
    • 2838
    IMO, M30. I think it looks better in an e30 than an m50. Period correct also. And m50s are played out. Unless you want to be like everyone else.
    Originally posted by Andy.B
    I was born on 3/25…
    • makeshift
      • Feb 2013
      • 131
      I agree
      • lukeADE335i
        • Apr 2013
        • 1386
        The M30 already has 208hp, so it's in your target range without a turbo :)
        My e30: OEM+ with M30B35
        • marshallnoise
          • Sep 2013
          • 3148
          Both have their fitment issues. But an m30 looks better in my opinion. The tech in the m50 isn't much more advanced. Start pricing stuff out and go from there.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • Bearmw
            • 1323
            Not that I've driven either but with 350-500 foot pounds of torque easily attainable the m30 option seems more attractive but if money is no issue then who knows?
            • makeshift
              • Feb 2013
              • 131
              True, I like to make my goals easily attainable
              Ok. I agree that the M30 looks better.
              It seems like we have come to a consensus heheh
              • dannyyisntt
                • 3141
                Seriously was a no brainer. M50s suck.
                • Razor1981
                  • Jan 2016
                  • 25
                  Why everyone hating on the M50 so much?
                  • SkiFree
                    • Jun 2011
                    • 2766
                    No hate ....
                    The M30 is just that awesome. Personally when I see an M50 swap it screams "Corners Cut! Compromises Made!"
                    ADAMS Autosport
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      500foot pounds from an M30?
                      Originally posted by flyboyx
                      i have watched my dog lick himself off a few times
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        M30. They are so easy to get power from and looks better then m50. Buddy here is running at 8 psi making close to 400hp ( hes got lots of head work) its still a beast of a motor.
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • EatsHondas
                          • Sep 2012
                          • 404
                          M30: SOHC 2-valve, Panzer-tank reliability, terrible gas mileage, torque everywhere, cheap, plentiful, simple, loves boost, one of Ward's Top Engines of the 20th Century (no joke, google it).
                          M50: DOHC 4 valve, better oem engine management, significantly less power/tq, nice gas mileage, also cheap, plentiful, and loves boost (go non-vanos for that). Basically an M20 with a 4 valve head, better engine management electronics, and a timing chain.
                          Both are cheap, reliable engines that excel in different territories, and are now both heavily documented, easy swaps. Yes I said easy. If you have played with legos as a kid and you're smarter than a monkey with a wrench, you can do both of these swaps. 99% of the necessary parts are OEM and already exist, implying you don't have to fabricate much, if anything at all. Study those system diagrams, figure out how everything bolts up, and go shred. Make an Excel sheet to keep your expenses in check, and start sourcing parts.
                          Make thy choice.
                          1989 325i Lachssilber Sedan
                          5-Speed Swapped
                          M30B35 Swapped
                          MegaSquirt MS3X
                          1987 325i Lachssilber Sedan
                          260k OEM Automatic Daily Baby
                          • Good & Tight
                            • Apr 2004
                            • 2057
                            600+ftlbs version M30, stock bottom end, stupid motor won't die.. :rofl:
                            Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                            ____________________________
                            E-mail Panayiotisx2@gmail.com
                            Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              This just proves the m30 is the best motor ever
