My M20 blew in the last 300 miles of a 2000 mile road trip a couple weeks ago. I've decided to swap in an M30 and turbo it. Im just asking for some assurance before I make a move.
Here's my plan:
-Remove M20 and see if anything is salvageable.
-Clean/shave/paint engine bay.
-Find an M30B35 in a junkyard 535i/735i. It should be older than 88' so the block is good for a turbo, right?
-Refresh from the bottom up. New seals, timing chain, timing guide, timing rail, tensioner, head gasket, rings, and bearings. Am I missing anything?
-Get a Getrag 260/5 tranny, gearbox, E34 radiator fan, flywheel from a pre-84 533/633/733 or E12, E36M auto driveshaft.
-Aftermarket E28 535i radiator, exhaust, E34 throttle cable, engine mounts (that put the M30 as far back as possible), thicker head gasket, TCD turbo kit, clutch.
-Put it all together.
-Learn how to tune or get it professionally tuned.
Hows this sound? Is there anything else I need to know before getting started?
Thanks for your time!
-Matt
P.S. I want to build a quick DD that makes anywhere around 2-300 hp with 10-15psi. I plan on driving it as soon as the M30's in, even though it will have a thicker head gasket and studs or whatever else I need to make it turbo-ready and reliable. Is that ok? It would only be like this for a few months until I have enough money for the TCD turbo kit.
Edit: That was a stupid question huh. I might be over thinking it because I don't have any money right now, and at my job I can use a laptop and look at car stuff all day :thumbup:
Here's a picture of my car:)
Here's my plan:
-Matt
