I have a 1987 325 that I'm planning to do a M30 swap with. I have a B32 and B34 engine and trans available for use. Both have around 200k on them and will be torn down to assess the condition. I was wondering if anyone had input as to which engine is a better candidate for the swap. Does interchanging parts from the B34 to the B32 have a mechanical advantage? A turbo is a distant goal for the future, but currently, cheap and easy power is my goal.
E30 Swap M30 - B32 or B34
B34!!!Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
No replacement for displacement. Especially combined with boost.Si vis pacem, para bellum.
New Hawtness: 1995 540i/6 Claptrap
Defunct too: Cirrusblau m30 Project
Defunct (sold): Alta Vista
79 Bronco SHTF BuildComment
Does anyone have any experience with using a b34 head on the b32 bottom end. Iirc the combustion chamber on the b34 is smaller. Combined with the flat tops of the b32 it should net a higher static compression ratio for cheap na power.
Am I on to something?
Ps the b34 uses dished pistons.Comment
B34 all the way it's the best for boost. Just get a b34 do a b35 intake swap and 1.3 motronic conversion.Comment
