who knows spark plugs?
  • G-Man the Visionary
    • Apr 2013
    • 543
    When warm, had a miss or stumble. Changed plugs, problem nearly stopped for a couple hundred miles. Problem came back. Changed fpr and added electric grease to temp sensors. Got better so wanted to change plugs again to see if that was the issue. So check out the pic, they look pretty good to me, but I'm no expert. Excuse short english, on crappy phone.
    Streetable poly mounts, trans mounts are here!
    http://www.r3vlimited.com/board/show...ght=streetable
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
    • Apr 2013
    • 543
    1-6 top to bottom
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
    • rmdashrf
      • Feb 2014
      • 207
      From that picture, they look good. I'd check that gap though
      • the imitator
        • May 2013
        • 1006
        I know with the motor I'm putting in, if you're simply cruising on the highway it sounds like there's a small miss, it's goes vvvvvvvdvvvvvvvvvvvvvvdvvvvv yes you have to make the sound.
          • Apr 2013
          • 543
          Thanks!
          LMAO... I tried to make the noise, sounded about right.
          Actually, dumped 2 things of fuel system cleaner in the tank and greased all the spark plug connections and coil connections. It's running waaaay better now. I'm thinking it may be an ignition problem, gonna check grounds and maybe get a new coil. Thanks guys!
          '94 318i
          '07 335i
          '11 X5
          '89 325ic m30b35
          • scoobydo
            • Sep 2013
            • 137
            Is this in an M30 and think you are using resistor plugs, this is not recommended depending on your ignition system. Not saying it is the problem
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Tried changing spark plugs wires.
              1991 318i 4dr slick top
              Mtech 2 turbo restoration
                • Apr 2013
                • 543
                Yes it's an m30 although I still have the coil from the m20 hooked up. I have brand new ngk platinums but didn't put them in since these looked ok. You think that would help? Thanks!
                Thanks, I'll give that a try soon as I have some cash handy, does seem very possible that that's the issue.
                '94 318i
                '07 335i
                '11 X5
                '89 325ic m30b35
                • Ether-D
                  • Sep 2011
                  • 2838
                  I may be incorrect, but I think platinum plugs aren't recommended. For why, Idk.
                  Originally posted by Andy.B
                  I was born on 3/25…
                  • scoobydo
                    • Sep 2013
                    • 137
                    Cheapo NGK's, or Bosch's are the way to go. Dont worry about platitums, or whatever flavour of the months the latest fandangled long lasting plug is. I think there has been multiple discussions on this in the past and people have thought they were improving things by putting the expensive plugs only to find the ignition system didnt like it.
                    • uturn
                      • Dec 2010
                      • 1001
                      NGK BPR5ES are stock equivalent and I run them in both my M30 and M20 powered cars. I'm also running a M20 coil on my M30 swap. Did you remember to change out your distributor cap and rotor before you dropped in your motor?
                        • Apr 2013
                        • 543
                        Thanks guys, unfortunately I did not change the cap and rotor... I hope that's not the problem. Well, looks like the governor in the trans needs changed so all that can be done at the same time. ..
                        '94 318i
                        '07 335i
                        '11 X5
                        '89 325ic m30b35
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          Cap and rotor would be next step.
