e30.de mounts
  • mycarisstillquiteshit
    • Aug 2014
    • 11
    e30.de mounts
    Did anyone else using e30.de mounts have to modify the support bracket for the intake manifold in order to make the mounts fit?
  • Red88
    • Nov 2008
    • 1161
    I do not have experience with this but I imagine that the plate that mounts against the engine is skinnier on the .de mounts. Nothing a stack of washers couldn't correct. It would go engine block>mount>washers>support bracket>bolt
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
    • kamotors
      • Nov 2007
      • 7102
      i couldn't use the support brace with the mounts either, so i just threw that out.
      7speedshop.com
        • Aug 2014
        • 11
        Yea i think I'm just giong to drill it out a bit. Thanks!
        • lukeADE335i
          • Apr 2013
          • 1389
          yep - I just slotted the bolt hole on my bracket to allow room for the engine mount.
          I doubt the support bracket fits without modification with any e30 swap mounts because you are using holes in the block that were never used on the e32 / e34.
          My e30: OEM+ with M30B35
