M30 Hp numbers
  • uturn
    • Dec 2010
    • 1005
    M30 Hp numbers
    Embarking on another M30E30 swap. The stock M30 should make about 205-210 hp, Alpina spec'd made ~254ish and turbo'd should be in the 300/400 range. Has anyone confirmed what numbers 10:1 pistons make in an n/a setup with stock cams? I'll go this route if it can pull off ~240 without any additional porting or flow work.
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    The high compression euro spec m30 pulled 218 hp which was 10:1 with the piano Pistons.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • Jb325is
      • 2137
      The euro pistons are bigger, I think 93.4mm vs 92.5. But they will bump compression to 10.5:1 with everything else still being b35. My car made ~250 with this combination
      - '88 m54 coupe
      <3
      • LJ851
        • 7919
        There are 3 M30 engines from the factory that produced low 200's in hp. They all were 3.5 liters, shared a very similar camshaft profile and were 9 to 1 CR or greater. All three of these engines have different cylinder heads with different port sizes/shapes.
        1) Early euro, (aka M90).
        2) Euro B34 (aka Dirty B34)
        3) B35
        Bumping the compression slightly (10 to 1) is not going to get you a lot of power in and of itself.
        Lorin
        The M30 is God's engine.
        • King Mufasa
          • Sep 2012
          • 530
          ^Dude that cock.. lol!!
          • brody
            • Jul 2009
            • 334
            With a stock compression B35, stock exhaust our MAF, simple head work and our cam, you'll make 220 WHP (260Bhp) and 230 WTQ (270 @ crank). With a bump in compression and same mods plus a good exhaust side we consistently see 250 to 260 WHP (300 bhp) and 260 270 WTQ (300 @crank) just to gove you an idea.
            Bumping the compression without an appropriate cam or flow work and your not going to gain much power. A bit of low end torque but you'll be running into cylinder heat problems and will not be able to take "full" advantage of the compression bump.
