M30b35 idle ~2200
  • frankie591
    • Feb 2012
    • 545
    M30b35 idle ~2200
    Hello all,
    Got my swap running and driving and trying to troubleshoot why my engine is idling at 2200.
    Engine is a b35 from an e24 635csi and I plugged my late model e30 325i harness into it with a few extended wires. I have no check engine lights and no vacuum leaks that I could find.
    My ICV was acting up so I replaced it with a known working one from my m52. My ideas so far would be a problem with the ECU, AFM or the FPR. I am looking to find some used ones locally to swap out and see if the situation improves.
    Any help or suggestions are appreciated.
  • Mr. Burns
    • Aug 2011
    • 3516
    which ecu are you running?
    don't quote me, but I believe you need to run a 179 ECU(e34 535) in order to get the values correct
    otherwise TPS signal?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • Mr. Burns
      • Aug 2011
      • 3516
      btw congrats on the swap!
      pics!! vids!!
      this is the swap I was going to buy off you lol
      • frankie591
        • Feb 2012
        • 545
        It is a 179 ECU. I've tried swapping the tps with my m20 tps and it didn't change anything so I don't think that signal is bad.
        • kronus
          • Apr 2008
          • 13028
          massive vac leak?
          cars beep boop
          • frankie591
            • Feb 2012
            • 545
            I guess I'll check again a little more thoroughly but I sprayed carb cleaner all over the intake top and bottom and didn't detect any major leaks.
            • Mr. Burns
              • Aug 2011
              • 3516
              Any luck?
              • uturn
                • Dec 2010
                • 997
                Throttle cable or stuck open charcoal canister solenoid?
                • frankie591
                  • Feb 2012
                  • 545
                  charcoal valve is plugged into the harness but not hooked up to the intake so that isn't the case. I used the charcoal canister port to feed my brake booster since my intake manifold didn't have a booster vacuum port.
                  I have a line on a spare ecu and afm to try but I can't get them until the weekend so I might be out of luck if I don't find any vacuum leaks. Really jealous of people who have junkyards with older bmw's in them. Anything around me is lucky to have 1 e36, never see anything older than that really.
                  • frankie591
                    • Feb 2012
                    • 545
                    Just as a follow up, it seems that either my ICV or however the ECU controls the ICV is acting up. I took the ICV off, plugged the hole in the rubber intake runner, and put a cap in the ICV hose going to the intake manifold with a 3/16" hole and the motor idles perfectly.
                    I think it is an ECU issue as the ICV I had on the engine is from my m52 and works perfectly on that engine. I'm getting a spare ECU this weekend so hopefully I can put the ICV back onto the engine without problems once I swap the computer.
