Hey guys. This happened a couple months ago. Replaced mounts with swag rubber ones and the right one has started to give, however it hasn't moved in awhile. And left mount is fine. Old mounts were like this too, right mount was screwed. What do I need to do to avoid this? Is it melted by the heat or, as the guy at the local mount shop said, has it been destroyed by the torque of the engine? I need something stronger clearly, what mounts do you guys use???
