Crank srokes & Rod lengths - fill the blanks!
  • Sean
    • 5793
    Ok, I need some facts that I can't seem to find out.
    Here's a list of cranks, and the strokes I know. Can anyone tell me if all the below is correct?
    Cranks
    M20B25 Crank --------- 74mm --- Cast
    M20B27 Crank --------- 81mm --- Cast
    M20B27 Diesal Crank --- 81mm --- Forged
    M52B28 Crank --------- 84mm --- Forged
    S50B30 Crank --------- 86mm --- Cast
    S52B32 Crank --------- 89.6mm - Forged
    Rods
    M20B25 Rod --------- 135mm --- Cast
    M20B27 Rod --------- 130mm --- Cast
    M20B27 Diesal Rod --- 130mm --- Cast
    M52B28 Rod --------- 135mm --- Forged
    S50B30 Rod --------- 135mm --- Forged
    S52B32 Rod --------- 135mm --- Forged
    The reason I'm getting all this is because I'm trying to find the best pair for a stroker. I want to go either 86mm or 89.6mm stroke - yea huge - but with that I'm going to need longer rods. Has BMW made any rods longer than 135mm? I kind of want to go with 140-143mm to help the rod stroke ratio - if that's even possible?? (am I just gonna run out of room in the combustion chamber?)
    The other question I have is, between the S52 and S50 did the cranks change? I'm under the understanding that the S50 has a Cast 86mm stroke cank and the S52 has a Forged 89.6mm stroke crank?
    Help me out! :)
    - Sean Hayes
  • Sean
    • 5793
    Found this page: http://www.bmwworld.com/engines/m52.htm
    Looks like the M52B20 has a rod length of 145mm.
    Pair that with the S52 crank at 89.6mm stroke
    If that works in an M20, you'd have a killer rod/stroke ratio and a 3.2 liter motor! (right? - or am I thinking wrong?)
    145/89.6 = 1.61 r/s ratio - not too bad actually
    Anyone know where I could get ahold of those rods?? lol Can anyone tell me if that would work in the m20 block with massively modified pistons?
    - Sean Hayes
    • plotfi
      • Mar 2012
      • 394
      bump
      feedback http://www.r3vlimited.com/board/show...32#post4540332
      1972 2002 Chamonix
      1984 325e Hennarot (M20B31)
      1988 325is Bronzite Time Capsule
      • whodwho
        • Jun 2008
        • 1547
        Originally posted by plotfi
        bump
        What part you are looking for information on?
        I know this is an old thread...
        M20B25 had a 75mm stroke
        Some more strokes to add to your collection
        66 mm (2.6 in) (M20B20)
        75 mm (3.0 in) (M20B25)
        76.8 mm (3.0 in) (M20B23)
        81 mm (3.2 in) (M20B27)
        M54B22 had a 72mm
        M54B30 had an 89.6 as well
        M50tu had 140mm rods
        M52tuB20/b25 had 145mm
        Not sure you could use 145mm you would have a tuff time putting 140mm rods with an 89.6 crank, MM uses a 135 & 138mm(not sure I think a smaller pin) rods with 89.6 & 86mm cranks with their kits.
        I am using 135mm with a 89.6 and it creates some challenges with fitting the rod small end between the pin and head of the piston(had to be milled for room). It also impacts the ring pack, the pin is up past the oil ring
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • plotfi
          • Mar 2012
          • 394
          stroker
          I am wondering why S52B32US with identical Rod/stroke ratio might be more long lasting than MM 3.2 m20 engine. There is a difference of .4 in bore diameter.
          M54B22 had a 72mm
          Not sure on the 145mm, but a M50tu had 140mm rods
          Not sure you could use 145mm you would have a tuff time putting 140mm rods with an 89.6 crank, MM uses a 138mm rods with kit.
          I am using 135mm with a 89.6 and it creates some challenges with fitting the rod small end between the pin and head of the piston(has to be milled for room). It also impacts the ring stack, the pin is up past the oil ring
          1972 2002 Chamonix
          • digger
            • Nov 2005
            • 6196
            only difference is going to be piston design such as shorter height, slitted (weaker) skirt that MM use to package it in the block, slightly larger cold clearances due to forged material vs cast and proper assumptions of piston growth (temp profile) during machining/manufcturing leading to more wear on pistons and bores particularly when engine isnt warmed up. i think an OEM S52 would last longer than MM if street driven as it had more engineering go into it.
            i dont think the bore size has much to do with life, as the amount of meat in the walls is reportedly similar (according to MM) though i dont have an S52 block to compare. when you go thinner the walls move around more and the rings arent going to seal as well. that's why with big boost or anything like that you might even lose more through rings on power stroke than you gain from the extra CC.
            i do wonder if the S54 and S52 use a slighty different material in the block though
            i thought the S50B30US stroke was 85.8mm not 86mm ?
            plus modified crank nose allows some diesel cranks to be fitted with 90mm stroke e.g. M57B30
            and to answer the 2006 question you cant use a 145mm rod with 89.6 stroke in an m20 block without using a deck plate
            • skitzy777
              • Jul 2016
              • 57
              to answer a 2016 statement what is a deck plate?
              I'm trying to rev my supercharged m20 to 9000 rpm preferably with a 81mm crank. I've got a 89.6mm but don't think it's possible. obviously will be going all forged stuff for light weight and roller cams from Rama.
              was trying to get the longest rod I can packaged into stroker.
              -E30 323i 1983
              -Honda CB250n 1980
              • digger
                • Nov 2005
                • 6196
                A plate that bolts to the top of the block making the deck taller, then you add sleeves through the plate into the block so it is a continuous cylinder liner. It is excessively complicated and not worth it for some additional rod length as the rod ratio wont be the difference between revving to some magical rpm as it is has a second order effect on the engine performance. If you want a higher rpm engine you should just make it a smaller engine (smaller stroke) and focus on more important things.
