Which selector rod should I use?? M30+G260(m30)
  • Mr. Burns
    • Aug 2011
    • 3516
    Hey folks...
    I've misplaced my selector rod I was going to use for my M30 swap.
    I have M30 engine mated to a M30G260 transmission.
    I'm issing all the components from a M20b25 shifting arm, with the exception of the shifter rod in which I don't have.
    Part # 11 in the below diagram.
    http://www.realoem.com/bmw/showparts...25&hg=25&fg=05
    should I get the shifter rod from a E34 or E30?
    I don't want to have the shifter all cockeyed in the cabin...
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Mr. Burns
    • Aug 2011
    • 3516
    Alternatively, what other rods could be used instead?
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      I used all e34 shifting parts for my swap. Had to shorten them by about 17mm
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Mr. Burns
        • Aug 2011
        • 3516
        thx, i'm sticking with all M20b25 for mine...beat on the street is it works just fine
        • Jb325is
          • 2137
          Yeah I think I used m20 stuff, didn't do anything to it
          - '88 m54 coupe
          <3
          • kronus
            • Apr 2008
            • 13032
            also used stock M20 stuff with no mods. There's a slightly shorter and a slightly longer M20 selector rod - look for the shorter one.
            cars beep boop
            • Mr. Burns
              • Aug 2011
              • 3516
              Ended up finding the longer one
              I'll need to shorten it, but won't get a measurement until everything is in the car.
              • kronus
                • Apr 2008
                • 13032
                they're only about 5mm different in length, it's not a huge deal but your shift knob will sit a bit further forward
                cars beep boop
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  The selector rod I have doesn't allow the the arm to sit level...not even close. It's going to be at least a 2" cut I'm guessing.
                  I got the rod for free, was told it was from an e30, but wasn't sure which engine.
                  • kronus
                    • Apr 2008
                    • 13032
                    do you have a getrag 260 or 265?
                    selector rod might have been from a m42 car.
                    cars beep boop
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      Getrag 260.
                      I have a feeling it's from a m42.
                      Either way I did manage to get the proper one :)
                      • glnr13
                        • 1334
                        which one is the proper one?
                        also are you running a shifter plate or the more modern setup?
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          Running the more modern style...
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            No that I think about it I used the euro selector rod from my zf tranny.
