M30 Swap Shift Carrier
  • ProfGhast
    • May 2011
    • 7
    Any other options other than shortening the factory carrier? I'd prefer not to have to cut and weld it. I've heard of using an e24 carrier? Not of the dimensions though.
  • LowR3V'in
    • 4209
    stock aluminum works
    • ProfGhast
      • May 2011
      • 7
      I'm using the 265/5 gearbox (removable bellhousing), and it sits way too far back. The shifter cup is sitting around 3-4 inches back. The stock carrier doesn't even fit in the space.
      • LowR3V'in
        • 4209
        You should of said so.
        • ProfGhast
          • May 2011
          • 7
          Yes I should have. Is there a shorter shift carrier from a different model?
          • Red88
            • Nov 2008
            • 1161
            Cut and weld. It's not hard just make straight cuts!
            Have you made a purchase from www.blunttech.com recently?
            sigpic<< wrecked
            • Doughnut
              • Oct 2007
              • 869
              You will have to cut and weld the e24 unit anyway (the steel plate type)
              ///Monstrosity. (OO≡≡[][]≡≡OO)
              Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
