Initial M30B35 Exhaust Setup
  • EatsHondas
    • Sep 2012
    • 404
    Just got the M30 minimally wired up and idling with no exhaust manifolds. I'll be looking to get the exhaust made in the next few days.
    Stock e34 manifolds > stock downpipes > Y pipe > 2.5" single > universal 2.5" in/out resonator > Magnaflow 12158
    It'll definitely be on the louder side, but how loud should I be expecting?
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
  • Lurker27
    • 821
    Not that bad, ran the above with 3" and some chintzy ebay universal muffler. It will annoy others but in cabin it's fine.
    Also just a b35 with a 4.10 diff was plenty of fun for hooning. I miss those days and want a second NA m30e30
    '89 335is +turbo
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      You'll be happy with the 2.5" Magnaflow, it won't be too loud.
      • EatsHondas
        • Sep 2012
        • 404
        Cool. I don't want obnoxious, but I do want potent. We'll see how it goes.
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        • ahlem
          • 369
          Try to design in a straight section or two in the event you need to add more muffler later. We used a similar set up on an M42 and it was loud enough to attract the attention of the State Patrol. I used two glass packs as resonators before a magnaflow clone on my m30 and am happy with the results. After adding a glass pack in addition to the Magnaflow on the M42, its got a good sound. The straight section was just long enough to add it in after donut man stopped me on the freeway for being too loud and missed the SUV that just blew by at 85.
          • EatsHondas
            • Sep 2012
            • 404
            So the additional resonator helped further quiet the sound?
            5-Speed Swapped
            M30B35 Swapped
            MegaSquirt MS3X
            • CorvallisBMW
              • 13039
              Are you running a cat? Those help quiet things down for sure.
              • EatsHondas
                • Sep 2012
                • 404
                I'd rather not, I'm going to start with no cat. Maybe a hi-flow or something if it's too loud.
                5-Speed Swapped
                M30B35 Swapped
                MegaSquirt MS3X
                • EatsHondas
                  • Sep 2012
                  • 404
                  It's loud as living hell at full throttle. There's no rasp, but the interior noise does interfere with normal conversation. It's acceptably quiet under very light cruising conditions, but if I get into it at all, it roars and takes off. It is a straight-thru exhaust after all, so now I know first-hand how much sound volume difference a cat (or lack thereof) makes.
                  5-Speed Swapped
                  M30B35 Swapped
                  MegaSquirt MS3X
                  • lukeADE335i
                    • Apr 2013
                    • 1389
                    A 2.5 inch single is pretty droney on an M30B35. I've never been 100% happy with the drone of mine, and I run a hi-flow cat. I put dynamat in various places on my rear bulk head, spare wheel well etc. to tone it down which helped a bit, but ultimately I'd like to go over to a twin 2 inch system like the e34.
                    My e30: OEM+ with M30B35
