Hi everyone, I am reaching out to you guys all the way from Sri Lanka :)
Would greatly appreciate if someone could help clear up some slight confusion I have regarding a M30 engine I recently bought to swap into my 316i e30.
I do not have any VIN information on the donor for the M30, so this is what I have;
Also the valve cover has the words BMW stamped, not the roundel, and has 3.5 stamped on the intake manifold and block, so I believe this is a M30B35.
However, the ECU I have got with this is Bosch 0261 200 061, what I have gathered about that online is below;
Bosch 061, ML3.3
BMW 12 14 1 288 138, 12 14 1 706 192
Does not use catalytic system
E28 535i, M535i 1/85 - 8/86
E24 635CSi, 9/84 - 8/86
E23 735i 9/84 - 6/86
Given that the engine code says 34 6k B - [where K is for catalytic] I just would like to confirm if this ECU works with this engine, and how I can identify which year this engine was made, your support would be greatly appreciated!
Bosch 061, ML3.3
