Alternate engine swap options?
  • Bones566
    • Dec 2015
    • 12
    Hi guys, new to the group here. Don't beat me up too bad. My question is are there any other possible engine swap options not listed here? A 2.3 sohc Ford Ranger 4 banger as an example. What is ultimately the smoothest up swap for a 325es M20B27?
  • J.Rizo
    • Aug 2012
    • 949
    you're gonna get told to search, by multiple people.
    @joshua.j.rizo
    Originally posted by SpasticDwarf
    Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
    BUY MY BUGATTI WHEELS:
    http://www.r3vlimited.com/board/showthread.php?t=377693
    WRITEUP TO MY RHD SWAP:
    http://www.r3vlimited.com/board/showthread.php?t=371904
    • Hooffenstein HD
      • Nov 2012
      • 1388
      Toyota 2GR-FE with J160 6 speed from BEAMS 3SGE.
      • Bones566
        • Dec 2015
        • 12
        I'm not biased on staying with the brand and small block Chevy/ Ford combos are what I'm seeing mainly. Certainly out of the thousands of engines out there, the handful listed here isn't the extent of possibilities.
        • Hooffenstein HD
          • Nov 2012
          • 1388
          Hence why I said 2GR-FE. As far as I'm aware, it's never been done before but it needs to be.
          3.5 litre V6, roller rockers, 6 bolt mains, 163kg service weight and that good ol Toyota reliability. Easy 200rwkw with a decent exhaust and tune.
          • Bones566
            • Dec 2015
            • 12
            Right, I gotcha . I was just adding to my initial post. I've had several Toyota Tacomas and minus the POS Rav 4 my wife had to have, they've been super reliable.
            • Blake B
              • Feb 2015
              • 150
              Mazda 13b! small package, would put the engine right behind the axles (mid engine) and would make the same power as a turbo m20 safely.
              They get a bad rap, but as long as your not wringing it out to 9k everyday or trying to make over 450+ hp out of its 1.3 liters they'll last plenty long.
              1990 325i Cashmere Beige
              "I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
              • Reichart12
                • Aug 2012
                • 2163
                Whatever you go with don't forget to get a Gallo 24 with it. Goes great with any engine.
                Instagram: Reichart12
                • totheredline
                  • Jun 2013
                  • 762
                  1uzfe is a very quick revving, reliable, and beautifully sounding engine.
                  = Heidi 1988 325 -> 335i. 7200rpm built M30
                  • lukeADE335i
                    • Apr 2013
                    • 1386
                    SAAB 2.3L turbo - bell housing is the same as GM Family II, grab a RWD gearbox from a Pontiac Solstice.
                    My e30: OEM+ with M30B35
                    • Hooffenstein HD
                      • Nov 2012
                      • 1388
                      Gallo 12 is better for handling though as it's much lighter.
                      • Hooffenstein HD
                        • Nov 2012
                        • 1388
                        I've got a B234 turbo, later model style with direct ignition if you're interested. I did a trial fit in an E30 though and it definitely needs a modded sump.
                        • Bones566
                          • Dec 2015
                          • 12
                          Oof! That Gallo engine seems to be not very common even in the US equivalent. Mitsubishi Montero?
                          • lukeADE335i
                            • Apr 2013
                            • 1386
                            Nah - happy with the M30 - too reliable to mess with too much - just thinking it was a swap that hadn't been done & would likely be reliable :)
                            If you want an interesting read of the 2.3L turbo Commodore that never was, check this out -
                            Would have gone ahead had Detroit not stepped in (as always).
                            • Hooffenstein HD
                              • Nov 2012
                              • 1388
                              Yamaha OX66. Don't ask me how to make it work though.
