Is this crankshaft still good?
  • Ryan335
    • Jul 2015
    • 45
    Hello r3v
    I'm rebuilding a m30b35 and I've found some cracks at the flywheel bolt holes.
    It seems like whomever did the clutch/flywheel impacted the bolts on and over-torqued them.
    There is small cracks on each hole, this one being the worst.
    Not keen on scrapping an otherwise perfect crank..
    Reuse/repair/replace?
  • Fsnow
    • May 2015
    • 184
    That would be a tough repair and I wouldn't want to use it as is. Do they spread apart more when you torque it properly to the flywheel? I don't think your crank seal would last very long. If I were you I would start looking for a good used one.
    1991 318is x 2 .
    • SkiFree
      • Jun 2011
      • 2766
      Do ya feel lucky ...... punk?
      ADAMS Autosport
      • Bearmw
        • 1323
        Just say no to crack. Seriously though do it right and do it once.
        • Ryan335
          • Jul 2015
          • 45
          Appreciate the advice, The cracks don't open up when I torque it properly and I assume it ran for quite sometime this way.
          Machine shop can do a grind-weld-lathe&tap but $$$
          All things considered I'd rather not clench my cheeks every time the clutch makes a funny noise so ill pick up another crank.
          preparing wallet..
          free pic
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • Ryan335
              • Jul 2015
              • 45
              Hey... I gots to know...
              Pulled the rear main seal before purchase and all is well. (So far)
              Now I've got a bunch of spare parts ;)
