E30 M30B35 swap questions
  • E30Bug
    • Sep 2016
    • 113
    Hi, I'm new to the forum, so please be gentle.
    I'm just trying to find out all the parts I need to do the M30B35 conversion in my E30. It's a stripped out 1989 318i shell, and I have a complete 1988 e34 535i auto (donor motor) and a 1990 E30 325i auto with all the running gear. I also have a M10 box which I believe bolts straight up to the M30B35.
    Firstly, what can I use off these other cars? Eg: wiring loom, prop shaft, diff, trans crossmember, etc, etc.
    So which model parts do I need:
    Wiring loom?
    Prop shaft?
    Diff?
    Brake booster?
    Brake fluid reservoir?
    Transmission crossmember?
    Pedal box?
    Slave cylinder?
    Master cylinder?
    Associated clutch lines?
    Suggested pressure plate, clutch plate and flywheel for M10 (g240 trans)?
    Shifter and linkages?
    Engine mounts? And which position (1, 2, 3) with a M10 trans
    Radiator?
    Radiator hoses?
    ECU
    Anything else I may have missed?
    Hope you don't mind all the questions.
    Thanks in advance for any help with this.
    Lincoln
  • Anthony B
    • Nov 2012
    • 308
    Wiring loom? m20 325i extend the injector loom, or the e34 loom you have
    Prop shaft? I had one built to suit, with serviceable uni's
    Diff? medium case as a minimum, depends on gearbox for the ratio. For the 240 you have 3.73
    Brake booster? standard e30
    Brake fluid reservoir? standard e30
    Transmission crossmember? use the one that you have with the 240
    Pedal box? long bolt & manual pedal(auto & manual box is the same)
    Slave cylinder? use the getrag 240
    Master cylinder? 325i
    Associated clutch lines? factory clutch lines, or customer make braided ones to suit(I did this)
    Suggested pressure plate, clutch plate and flywheel for M10 (g240 trans)? unsure on this one sorry
    Shifter and linkages? can use the sheet metal mount for the 240, or modify to suit the s2 shifter
    Engine mounts? gargastic, push the engine as far back as possible
    Radiator? e28 535i mounts to the e30 chassis
    Radiator hoses? e34 535i
    ECU? Unsure of the number on mine, use a manual e34 535i one where possible
    Anything else I may have missed? probably, but its hard to pin point everything at the start. Get a case or 3 of good Beer none of that XXXX nonsense & enjoy the swap
    • mila325
      • Sep 2015
      • 82
      Not really the right section for this one buddy. I don't have anything to contribute besides that.
      • flyboyx
        • 8371
        welcome aboard. this is going to be moved to the m30 section. while you are at it, go check out that section and spend a couple days or perhaps a week of your spare time reading the swap threads there. everything has already been posted there many many times over.
        from the transmission back, you can technically reuse all the parts you have from your m10 car. its probably not really recommended though. the getrag 240 isn't designed for m30 torque. if you intend to launch your car somewhat often, that tranny won't last you very long.
        Gigitty Gigitty!!!!
        • bangn
          • Sep 2011
          • 760
          the old "first time poster, no contributions but answer all my questions because I cant be bothered searching for it" chessnut.
          sounds like you are going to struggle hard at this project if you have to ask what to do with your clutch slave and master.
          Boris - 89 E30 325i
          84- E30 323i
          • E30Bug
            • Sep 2016
            • 113
            Thanks heaps Anthony, your a legend, appreciate the effort you went to answering all my questions.
            • E30Bug
              • Sep 2016
              • 113
              Thanks for clearing that up. Still learning my way around here.
              • E30Bug
                • Sep 2016
                • 113
                Thanks for the welcome flybox. Yeah I really didn't know where to start on this site as it is the first time I've been on it and didn't realise there was a specific section. I will find it and do some reading as you say.
                • E30Bug
                  • Sep 2016
                  • 113
                  Bangn, firstly, yes I'm a FIRST TIME POSTER, how the hell can I contribute when I literally registered and asked my questions? What would you have liked me to contribute? What could I tell you? Apparently I have no idea and I'm going to "struggle hard at this project!!"
                  I didn't "search for it" walnut, because I don't even know my way around this site yet, but I'm learning.
                  Haha, you have no idea of my experience so what gives you the right to make judgement.
                  I simply asked about the clutch slave and master in case it was suggested to use the e34 ones because they may have been bigger, I don't know. By the way, I did not ask "what to do with" my clutch slave and master as you state. I simply asked off which model could/should I use.
                  Cheers for your help.
                  • bangn
                    • Sep 2011
                    • 760
                    You've basically asked every single question in relation to doing an engine swap. That tells me you have no idea
                    You didn't search for it because you couldn't be bothered putting in the time to do proper research.. Google it you peanut, look at various forums and what everyone else is using/done.. Then come up with a list of what you need to do.. That is where you can ask questions.. "I read it says to do this, but another guy says to do this could I get confirmation. That tells everyone you bothered to do your research and at least tried.
                    the clutch and slave is simple. Its the same master and slave used in all E30's, E28s and others. If you bothered to do some research on google to see what engines they suit you would of seen if it suited
                    3rd link google search.. spoiler alert. Like the slave cyl they are all the same regardless if its an E30, E28, 4 cylinder shitbox or 3 litre orange juice.
                    https://www.turnermotorsport.com/p-3...25is-325xi-m3/
                    I get you may not find every answer you want on google but fuck me at least try instead of relying on everyone else to do the legwork for you.
                    People get tired of people signing up to forums just to ask a question, people answer that question and they generally fuck off elsewhere because they got what they came for.
                    Boris - 89 E30 325i
                    84- E30 323i
                    • TobyB
                      • 5280
                      :popcorn::popcorn:
                      t
                      • MR E30 325is
                        • Dec 2008
                        • 3300
                        Oooooooohhhhhhh!
                        My previous build (currently E30-less)
                        http://www.r3vlimited.com/board/showthread.php?t=170390
                        A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                        • keyland
                          • Apr 2009
                          • 67
                          Pretty helpful post.
                          To add a bit, you can also use certain drive shafts with certain transmissions. If you come across an E28 or E34 manual trans, those have what's called a 'large guibo' output flange and the driveshaft from a super eta 325es bolts right up (this is what I have).
                          You'll need to custom fabricate engine mounting brackets or as said above, pony up to get some from garagistic. The motor mount pads will be from your 325 donor, or buy some stock replacements for said car.
                          I'm assuming you're RHD, so from what I know, RHD swaps need the throttle cable from the E34 donor.
                          Folks will reccomend Frank M's swap guide. I bought it, it was alright. A little too wordy and it didn't tell me anything more than I learned through a couple weeks' research
                          This is a pretty solid guide to get started, however some things have changed since it was written: http://www.e30zone.net/e30zonewiki/i...ine_Swap_-_M30
                          For wiring it should be a plug and play affair in a late model E30. You will want to use the instruments from the 325 or at least transfer the coding plug so the tach works right. Spend some time learning to read the factory wiring diagrams just in case. See here for PDF versions: http://wedophones.com/BMWManualsLead.htm
                          Untwist your panties.
                          • E30Bug
                            • Sep 2016
                            • 113
                            Thanks for your input.
                            As keyland said.
                            • E30Bug
                              • Sep 2016
                              • 113
                              Thanks keyland, yeah I agree, Anthony B post was very helpful, as is yours.
                              Much appreciated.
