M30 guys whats your coolant gauge at?
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    So i have my cooling system routed like the one in this picture with an e36 mishimoto rad and 75 degree thermostat. At idle in my drive way it sits directly at half way. How ever when cruising its sits at 1/4 there isn’t any air in the system or leaks. Anyone out there have similar setup and temp?
    Im thinking of wiring in a legit coolant gauge i have to see the actual water temps. Thoughts?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • kronus
    • Apr 2008
    • 13032
    Why do you have a 75 degree t stat
    cars beep boop
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Got a low temp thermostat since the car will be mostly driven in the summer to help prevent it from getting hot.
      • kronus
        • Apr 2008
        • 13032
        Your ecu will see the low temp and fuck around with the mixture to try to get the engine to warm up. You should run a factory temperature thermostat.
        cars beep boop
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          that would explain the extreme rich running condition
          • e30davie
            • Apr 2016
            • 1788
            This is not How it works.
            A thermostat in working order regulates temperature to its specified temp.
            Your incorrect thermostat is just making your engine run too cool. Probably making it slower and less fuel efficient:)
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Well I’ve ordered a new thermostat got an 80 degree one
              • lukeADE335i
                • Apr 2013
                • 1386
                I run a 71 degree thermostat. BMW ran these from factory in their hot climate pack - places like Australia and Saudi Arabia, so maybe the extra headroom does something?!
                Car runs around 1/3rd (just over 1/4) on the cruise, and gets up to half stopped in traffic due to my 80 degree fan switch. One day I might try a Porsche 75 degree switch if my 80 degree one packs up, but it all works fine.
                I have had zero overheating issues vs. the many problems we seem to hear about on here ;-)
                My e30: OEM+ with M30B35
                • e30davie
                  • Apr 2016
                  • 1788
                  My 82deg one works fine up here in Queensland. No overheating either. Sits at 82deg on my COD temp gauge no matter what temp it is outside.
                  • Bearmw
                    • 1323
                    My car runs just about like Luke's car. No issues.
