wtf is going on w/ my car?
  • EWAustin
    • Sep 2006
    • 234
    A few days ago I PM'd Jordan asking if he knew anything about this, but he hasn't responded yet.
    I also posted to the BMWCCA northstar chapter message board asking if anyone local had a Peake tool. That post was 3 days ago, and there have been no new posts on that board.
    I haven't gotten around to metering the AFM, but I will one of these days. Also, I'm intrigued by the Crank Position Sensor possibility. I'm going to look into that aswell.
    Eric Austin
    1990 325i Sterling Silver
    ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
    • AndrewBird
      The Mad Scientist
      • 11897
      Scroll down to post number 71. This was Jordan's problem. All he did was bend the "arms" a bit so the contacted new surface. Solved his problem.
      • Quik325ix
        • Mar 2005
        • 381
        Originally posted by NitroRustlerDriver
        http://www.r3vlimited.com/board/show...&highlight=AFM
        so what do i do???? someone walk me through this if you can..
        • EWAustin
          • Sep 2006
          • 234
          SWEEEEEET!!!!!!!!!!!!!!!!!!!
          I'm gonna go try this!!!
          (quik, I'll go figger it out and get back to you in a bit)
          Eric Austin
          • Rocla
            • 922
            Those of you runnig models with crank sensor on front of engine, check that the plastic cover for crank sersor wire and oilpressure sender wire in front of timing cover is intact.
            I've stumbled with that sort of problems too.
            Twice I've discover that cover is missing and letting the wire to rub with waterpump pulley.
            When you accelerate, fan blow will move the sensor wire and put it contact with the pulley and make it short.
            When revs drop the wire will come off the pulley and everything will work again.
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
            • EWAustin
              • Sep 2006
              • 234
              I haven't gotten around to it yet, but I haven't had the problem since I reset my ECU...
              Eric Austin
              • Quik325ix
                • Mar 2005
                • 381
                how do you do that? And i had a little bit of luck just tinkering with the TPS...so i definately think that could be where the problem lies.
                • EWAustin
                  • Sep 2006
                  • 234
                  I disconnected the battery cables waited a second then touched the two cables together for about 30 seconds, then reconnected them. Just be sure to not connect the battery terminals by accident...
                  The DME has to re-learn how to run the engine, so just let it idle for a few minutes afterwards, and then take it for a drive.
                  This fixed my high-idle problem for a few minutes too. Then the CEL came back on and it idled at 2000. I can't wait for that Peake tool to get here.
                  Eric Austin
                  • Quik325ix
                    • Mar 2005
                    • 381
                    yea so that definately did not work....one of the two screws that holds the TPS on was too stripped to even think about getting off....and after reseting the ECU and putting everything back together, i now have an idle problem and a CEL comes on when the car is left to idle or is at a constant throttle position....so now what??? im thinking seriously about lighting the bitch on fire and rolling it over a cliff, taking the insurance money and buying a 90s toyota corolla...jesus....
                    • Quik325ix
                      • Mar 2005
                      • 381
                      i apologize for that blasphemy...i was frustrated
