Honda K24 swap interest?
  • rturbo 930
    • Dec 2005
    • 2625
    Originally posted by rover215
    I think the only thing I'll miss is the sound. Hard to beat the sound of an M20. Even my all-torque-and-no-poke eta sounds great under load. I don't think most 4 bangers sounds that great, but I'll manage :)
    Yeah, that's really the major thing holding me back, and also keeping it BMW/original-ish. The M20 is a great sounding motor even by the standard of inline sixes. Personally I think the F20c sounds quite good, and the K series doesn't sound quite as good, but still pretty good as far as four bangers go, but it doesn't hold a candle to the ol' M20.
    My M20 has given me a lot of trouble though - I've had this car since 2011, it didn't idle right when I bought it, but I figured it was something simple. Seven years later, still doesn't idle right even though it has all new gaskets and even an entirely different block and head - because the original motor spun a bearing, and then the replacement spun a bearing after <2k miles.
    ...So as much as I like it, and want to keep it, if it gives me any more shit, it's gonna be makin' way for a K series.
    • KMiata
      • Mar 2018
      • 43
      Thanks for the feedback guys. Good to see that this idea would be generally welcomed in the E30 community.
      I don't expect that this would be for everyone, but there's enough appeal that we want to see it happen.
      I love the sound of a straight six, but a rowdy high RPM K series is also pretty special:
      David Calzada
      KMiata Inc.
      KMiata.com
      • thebutterson
        • 463
        I see the guys at Speed Academy are doing a K-swap on a 240sx which is also front sump. I imagine the same oil pump and pan setup would work on an E30.
        • Jaker
          • Oct 2013
          • 234
          I'm pretty sure I'm going to have to get very creative with my oil pump setup. The E36 crossmember appears to sit directly below the oil pump drive (chain/sprocket) and I only have about 5 1/2-6" clearance from the crank centerline to the top of the crossmember. This is just eye balling though. I've yet to place the engine into the engine bay of the car. Measuring the K20 crank centerline to just slightly below the sump pickup looks like about 8". But that's back a ways from the crossmember.
          • KMiata
            • Mar 2018
            • 43
            We have a K24 physically in an e30 chassis right now. Pan and oil pickup needs to be custom but it's all very doable. Way easier packaging than the Miata chassis gave us!
            David Calzada
            KMiata Inc.
            KMiata.com
            • djjerme
              • 5082
              ..but how far back does it sit in the engine bay KMiata? I think the benefit to doing this swap is being able to push the CG back more to almost centered..
              2016 Ford Flex
              • agile30
                • 832
                It should sit pretty far back. I doubt it would sit too far forward. No reason it cant sit against the firewall i dont think.
                Originally posted by Good & Tight
                It takes real man to mount a big woman, all you haters are just scared boys.
                • djjerme
                  • 5082
                  ..oil pan clearance would be a deciding factor.
                  2016 Ford Flex
                  • agile30
                    • 832
                    Well if they have one in the car already. And him saying that it will need a custom pan and pickup. Hopefully they can design it with a good capacity and sits high.
                    • KMiata
                      • Mar 2018
                      • 43
                      Pan clearance can easily be made to keep stock ground clearance, and the transmission will be mounted in the stock location, so the engine sits all the way back like any BMW engine would.
                      David Calzada
                      KMiata Inc.
                      KMiata.com
                      • djjerme
                        • 5082
                        Cool. Be curious to see the mock up once you are ready to share.
                        2016 Ford Flex
                        • ahrensNW
                          • Mar 2015
                          • 1716
                          Giggling with excitement haha
                          Hank Ahrens
                          1984 Alpine Coupe
                          1978 911sc
                          • Chrisbike
                            • Mar 2015
                            • 688
                            This is really cool
                            Build Thread
                            https://www.r3vlimited.com/board/sho...d.php?t=419655
                            Parts Thread
                            https://www.r3vlimited.com/board/sho...d.php?t=408302
                            • rover215
                              • Jan 2018
                              • 49
                              KMiata- what're you thinking for best wiring? Power steering options? I'll be keeping my air conditioning and heat, but I think there will be lots of wire elimination. And is the drive-by-wire an issue?
                              I'd also like to see how close in size/ shape the TSX gauge cluster is (2008) to the stock e30 cluster. They're similar. Hoping to get my engine by June.
                              • ahrensNW
                                • Mar 2015
                                • 1716
                                Is power steering really needed for a k24? I'd be curious about the swap weight compare do a stock m20 or m42. I dd my 318is without power steering and it's manageable, I'd put money on a k24 weighing about the same. Curious about drive by wire as well, since I'm pretty sure at least some k20s came with a throttle cable.
                                Hank Ahrens
                                1984 Alpine Coupe
                                1978 911sc
