Honda K24 swap interest?
  • KMiata
    • Mar 2018
    • 43
    #541
    Originally posted by rover215
    And still running the "2002-2004 RSX Type S harness from a K20A2, or 2003-2006 Honda Element manual harness" depending on which engine management we choose to use?
    Correct. Although we will probably just support Hondata Kpro for the E30. And you can use any 2002-2004 RSX harness, including an auto one, so that helps a lot.
    David Calzada
    KMiata Inc.
    KMiata.com
    • Shangsta
      • 1485
      #542
      Im soo excited to hear updates from the upcoming track testing
      :shock:
      • JonJonE30
        • Feb 2020
        • 9
        #543
        So regardless if we are using a k24a2, or a k20, we will need to run the 2002-2004 rsx harness?
        Hope the weekend goes well for you guys!
        • Mohit
          • Nov 2013
          • 80
          #544
          Is AC something can be easily retained with the KMiata/garagistic/other swap kits? Kinda necessary for me where I live.
          • KMiata
            • Mar 2018
            • 43
            #545
            Yes, should be doable since the stock K A/C compressor will fit in the stock location. Our car has the P/S pump mounted down in the A/C compressor spot, so you'd just need to put that somewhere else. We're working on a couple ideas to make everything compatible together.
            David Calzada
            KMiata Inc.
            KMiata.com
            • Rev Run D
              • Feb 2013
              • 392
              #546
              TL;DW: We fried the KPro, but we're trying to make it compatible with 3 different transmissions and we're trying different oil pan designs.
              • Rev Run D
                • Feb 2013
                • 392
                #547
                Antipurist Fucatypr
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #548
                  Are you sure that's a Jet Rag transmission?
                  • Motheye99
                    • May 2018
                    • 853
                    #549
                    S2000 trans?
                    91' 318is 90' 325is
                    Originally posted by Sonny
                    Buy the E30s, they ain't gonna last long
                    E30 can make you, E30 can break you
                    "He who controls the Nova's, controls the Boomers"
                    • Shangsta
                      • 1485
                      #550
                      So garagistic just sold out of their first run of kswap mounts but i haven seen anything showing that they got their swap running yet. Fucatypr any news on the antipurist swap/ harness? Kmiata has theirs running andhave done some track testing. I know they wanted more testing till they released any more info. Just wondering if you are doing non track testing KMiata till the track opens up again
                      :shock:
                      • KMiata
                        • Mar 2018
                        • 43
                        #551
                        Yeah we are a bit stuck right now thanks to the tracks all being closed. The car is solid, we are just making a couple of small tweaks. We never sell parts without doing rigorous testing first. Fixtures are already built for our oil pan and mounts, but nothing goes into production until it's 110% proven. Despite the slow down, I don't see any reason why we can't have a very complete package in people's hands this summer.
                        David Calzada
                        KMiata Inc.
                        KMiata.com
                        • rover215
                          • Jan 2018
                          • 49
                          #552
                          So KMiata, does this mean a custom pan is required for mounting the K to the stock e30 subframe? Sounds like a yes.
                          • KMiata
                            • Mar 2018
                            • 43
                            #553
                            Yes, absolutely.
                            David Calzada
                            KMiata Inc.
                            KMiata.com
                            • Shangsta
                              • 1485
                              #554
                              Awesome I am looking forward to this, its been a long time coming
                              :shock:
                              • Andrew325is
                                • Jan 2008
                                • 1212
                                #555
                                This is really interesting. What concerns me about these custom swaps though is the ease of getting replacement parts. For example, let's say there's a limited run of conversion parts made. Then down the line you crack the oil pan and you're out of luck. So here's my suggestion: Make the oil pan a 2-piece like on a stock E30 4-cylinder engine and make it so the lower pan is an off-the-shelf item, such as the M42 lower pan. That way if you break it, which we know will happen on lowered E30s, you can quickly get a cheap replacement. So that's why my preference always goes to engine swaps that use off-the-shelf parts.
                                Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
