e30 M43 swap
    e30 M43 swap
    I have a e30 316i (M40B16) 1989 with getrag 240. I want to swap the engine to a M43 (M43B19). This m43 engine have a automatic transmission.
    Will my getrag 240 gear box , Flywheel and clutch pack fit to the m43 engine ?
    Thank you
    The M43 certainly is not an upgrade over an M40, even 1.6 to 1.6. But I believe they do share the same blocks, so they should be an easy swap, and your G240 should bolt up.
      Thank you very much!! Engine no says it is 1.9L
