New 335is
  • bmw335isturbo
    • Mar 2006
    • 218
    New 335is
    1986 BMW 325 2 DOOR (M30 SWAP) ~2600lbs stock
    1991 535i M30 Engine (3.5l inline 6) 190k Mi
    • Turner Motorsport Jim Conforti Performance Engine Chip ~235hp at the crank
    • Bosch Design II (4 nozzle) 19lb/hr Injectors
    • New Water pump, Thermostat, Spark Plugs
    • Ireland Engineering Urethane Race Motor Mounts
    • e30.de M30 -> E30 Motor Mount Brackets Engine Position III
    • Fully Custom Dual 2.25” Exhaust with High Flow Magnaflow Catalytic Converter and Stromung e30 M3 Rear Muffler Section (Very European Sound!!)
    • Brand New E28 535i Radiator
    • Zirgo 16” 3600cfm Electric Fan
    Drivetrain
    1991 535i Getrag 260/5 transmission (5 speed) 190k mi
    • JBRacing Lightweight Flywheel
    • SPEC Stage 3 Clutch Kit
    • UUC Urethane Racing Transmission Mounts
    • New Driveshaft from Driveline Services of Portland
    • Understeer.com Short Shift Kit
    Suspension
    • Ground Control Coilovers
    o Spring Rates: 425F/450R
    • Koni Sport Adjustable Shocks
    • Ireland Engineering Race Fully Adjustable Front Camber Plates
    • Ireland Engineering 25mm Front Sway Bar and Mounts link links bushings
    • Ireland Engineering 22mm Rear Sway Bar and Mounts link mounts bushings
    • Ireland Engineering Urethane Race Rear Subframe Mounts
    • Ground Control Rear Shock Mount Reinforcement
    • Urethane Rear Trailing Arm Bushings
    • E30 M3 Offset Front Control Arm Bushings
    • New Control arms and Tie Rods
    • H&R Hubcentric 4x100 15mm Spacers
    • Genuine SSR GT1 17x7” Wheels (4x100) 17lbs each Lightweight Race Wheels
    • Tires are Bravus Bavarium in the rear and Bridgestone RE750 Fronts (215/40/17)
    Brakes
    • Brembo Rotors Front Rear
    • Stainless Steel Braided Brake Lines
    • ATE Racing Super Blue Brake Fluid
    • Pagid Front and Rear Performance Brake Pads
    Misc
    • Prolumen HID Kit 6000k H1 Bulb
    • European Ellipsoid “Smiley” Projector Headlights
    • Viper Alarm
    • Kenwood 9102 Amp (1700 Watt)
    • Sony 1502 Amp (760 Watt)
    • 1991 535i Stock Speakers
    • Sony CD Deck
    • Alpine Type R 10” Sub in Custom Ski Pass Enclosure
    • Schucks Auto Supply Leatherette Racing Seat in Driver’s Side
    • Tucked Front and Rear Bumpers (Front is Color Matched to Body
    1986 335is-1988 335ist -1991 335istsigpic
  • euroshark
    • Apr 2006
    • 3491
    Ooooooh, nice! Mines an '84 325e shell, '81 Euro 3453cc, Getrag 265, and 2.93 open (also for now)... Can't wait to see pictures!
    • bmw335isturbo
      • Mar 2006
      • 218
      what is the comp on yours?
      also is the head the same as the e34?
      I will have to pull my book and do some reading not sure what the diff is between euro-us. Euro's had some good parts.
      The 335i's are fun to drive, How do you like the gearing over-all
      My Email is bmw335isturbo@yahoo.com if you have any Qustions down the road
      • euroshark
        • Apr 2006
        • 3491
        It should be 9.3:1. The head was milled .007", but I doubt that would raise it signifigantly. Stock they put out 218hp and just over 230ft/lbs according to the 6 Series Enthusiasts Companion. When I convert back to motronic I am planning on a 282 cam to replace the stock 264 (euro spec), and maybe some headers if I can find some that fit.
        I have not driven it yet because the buy I am getting my driveshaft from has apparently fallen off the face of the earth!! So.... It will be a little while yet, but I am about to get started on the exhaust started, so it is making progress!!
        • bmw335isturbo
          • Mar 2006
          • 218
          sounds good for the summer.
          are you haveing a CAT put on the exhost?
          • euroshark
            • Apr 2006
            • 3491
            Hell no! In fact, because I am doing the exhaust on the cheap, by myself, in my garage... I'm just going with a single 3" pipe, maybe a resonator, glasspack, or something, and a decent looking muffler. It will flow more cc's per minute than the stock 6 series exhaust (which was clearly designed for torque), so it should make a little more power. ...Though that's not what I am shooting for. If I lose some torque, big deal, it's a 700lb lighter chassis than the 6 it came out of, and that car hauled ass!!
            • bmw335isturbo
              • Mar 2006
              • 218
              that's cool but 3" might be a little big. Factor in all the bends if their manderil bent bends that could be bad mabe not noticeable but bad over time. little back pressure will infact help.
              If it was me and this is just my N/A I would not go any bigger than 2 1/5 inch but that is with a good mufler.
              I went with 2 1/4 and it ran fine
              • euroshark
                • Apr 2006
                • 3491
                Hmmm, well my original plan was 2.5" ID pipe, single all the way back for cost effectiveness until I find a set of headers... I bet that would work actually.
                The stock 6 series pipes are as follows: Two manifolds with ~45mm ID pipes into one ~60mm collector (2.35in), to two 45mm pipes all the way back (1.77in). So if we figure the area in cc², the stock system has a static area 3179.25mm². A 2.5" ID single system is 3165.32mm²... Not a very big difference at all.
                I suppose that is the way to go! Especially since the motor is stock right now...
                • bmw335isturbo
                  • Mar 2006
                  • 218
                  your plan sounds good
                  just rember little back pressure is good.
                  • euroshark
                    • Apr 2006
                    • 3491
                    When you say you went with 2 1/4, is that a single or twin pipe setup? I was a little unclear on that.
                    • bmw335isturbo
                      • Mar 2006
                      • 218
                      single i wen't for less restriction that is why I needed a good muffler for little back pressure.
                      Make sure if you go that rout down pipes are same leingth if not over time do the math frount 3 cyclenders, back 3 cyclenders you wan't to make them as equall as you can.
                      • euroshark
                        • Apr 2006
                        • 3491
                        Ahhh, so you have one 2 1/4 inch pipe for one set of 3 cylinders, and another 2 1/4 pipe for the other 3 cylinders?
                        • bmw335isturbo
                          • Mar 2006
                          • 218
                          Not quite 2 manifolds 2 -2" down pipes then the "Y" were the O2 bung is and the single 2 1/4 exhost pipe into a muffler
                          • euroshark
                            • Apr 2006
                            • 3491
                            Gotcha, sounds a little restrictive for the M30! But if it works, good!
                            • bmw335isturbo
                              • Mar 2006
                              • 218
                              It sounds restrictive but back pressure will give you power just don't go over kill.I am just telling you what I did and it worked well but little loud.
