Need some ideas........
  • bmw335ist
    • Apr 2004
    • 100
    Thoughts .......
    My 86 335is runs and drives good. But it needs a head gasket, door locks and some other little adjustments.
    I also have a hard to find e30 91 318is. No sun roof, black on black, nice interrior. This is the car I am not sure of?
    Choices..
    1. Extream: Send the car to my cousin's shop in beaverton for an extream role cage, then my turbo power plant and go from there.
    2. Sell the car and try to recover what I have into it.
  • auto da fe
    • 124
    From experience, option 2 is never going to happen. That is, the "recover what I have into it" part. Since you cannot have too many BMWs, keep what you have AND search out your dream 318iS.
    • bmw335ist
      • Apr 2004
      • 100
      "recover what I have into it" I am not really worried about It's more or less building a car that will support the power that I have.
      I just said the 318 because the body is stronger that most e30's "No Sunroof"
      • euroshark
        • Apr 2006
        • 3491
        Pssssh, screw the 318. Head gaskets are easy, seriously... It's a lot of work, but it's nothing that you can't do if you are moderately skilled in DIY mechanics.
        You have a 335 dude, no 318i / is is going to provide the same amount of fun or be nearly as cool (I am biased, of course )... Fix your 335, get a cage, and proceed with your plan to turbo it. A sunroof shouldn't really be a big factor once you have a cage anyway, plus you remove it and weld up the roof if really want it gone badly enough.
        • bmw335ist
          • Apr 2004
          • 100
          Ok.
          This might be my falt.
          I have a insured my daily driver witch is my 86 335is also my 97 ford f150 work truck that is in my sig light blue. Thoes will not be touched.
          I also have a black 1991 318is rolling chell This hole thred is about turning the 318 into a 335isturbo drag/show car and I have enough resorces to fab up any thing I want and/or will work in this job
          The question is what to do with the 318. ether way this is just the hobbie/funcar and hear soon I will have some time on my hands
          • euroshark
            • Apr 2006
            • 3491
            Ohhh... haha, yeah, swap the M30 into the 318 body, that's a good idea!
            • george graves
              • 19995
              A e30 w/o sunroof will never be much stronger than one with. The sunroof is like a round hole.
              Take a engineering class, structures don't need volume to have strength. Case in point - the "I" beam, bridges, buildings...shall I go on?
              Drill a *huge" hole in a 2x4. Is it any less "stiff"? Nope? Can you you break it easier? Yep...
              Two different things.
              My 2 cents - now, WHAT were we talking about?
              Originally posted by Matt-B
              • bmw335isturbo
                • Mar 2006
                • 218
                I was trying to decide on a track car I want an e30m3 but $$$$$$$$$$$$$$ just to take it apart so I will go with the chell I already have the 91 318
                1986 335is-1988 335ist -1991 335istsigpic
                • bmw335isturbo
                  • Mar 2006
                  • 218
                  OK I made up my mind starting mid next month the 318 will be my track car it already has a date with a weilder for a roll cage
