M30 exhaust size....
  • george graves
    • 20003
    Well, using the m30 down pipes is a no brainer, but being I was short on cash, I had the exaust shop tie the m30 down pipes to my stock exhaust....
    At some point I want to do it right...
    I'm thinking of a single 3" set up from a "Y" at the down pipes to a 3" cat, all the way to a muffler. All single 3" stuff.
    What do you all think? Could be a plan for a cheap good sounding set up?
    I did find this that you will (I DID) find interesting
    LINK: http://home.mindspring.com/~scrappycrow/e28exhaust.html
    So what you all say? single 3"?
    Originally posted by Matt-B
  • bmw335isturbo
    • Mar 2006
    • 218
    for N/A I would not go any lager than 2 1/2
    FI I would go back to 3" mandrel bent
    1986 335is-1988 335ist -1991 335istsigpic
    • drifty340i
      • Oct 2004
      • 1076
      Yip 2.5inch max!
      sigpic340hp V8 e30 FINISHED!!!!!
      Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
      NEW One on the track :)
      http://www.youtube.com/watch?v=K-AX5SzSLnk
      Cleaning up some 911s and Jap turbos
      http://www.youtube.com/watch?v=Ad79wsLdle4
      • drifty340i
        • Oct 2004
        • 1076
        Im using a 2.5inch mandrel bent pipe on my v8! and thats ideal for my engines size
        • george graves
          • 20003
          Wow, then I was way off...Thanks - I'll keep that in mind.
          So 2.5", and think that would also be plently for 8-10 psi of boost?
          • euroshark
            • Apr 2006
            • 3491
            Most likely plenty for 8 to 10psi. You can do the math to figure out the ideal volume of your exhaust system based on the maximum speed of your motor and it's size.
            • drifty340i
              • Oct 2004
              • 1076
              2.5 will be plenty for 10lbs
              • bmw335isturbo
                • Mar 2006
                • 218
                well if you are going to switch latter to fi then that breings a lot of ?
                basicly for turbo you are not going to want any restriction 2.5 is going to work but how well? if you try to push 10psi in a 335 HEAT will be your biggest problem
                • JoeMadoo
                  • 936
                  I'm building a full 3 inch exhaust system right now for my 335i with a high flow magnaflow cat and 3 in dual 2.5 out magnaflow universal muffler. I plan on turbo-ing it next summer so I fugured it would be a good idea to build a turbo exhaust now.
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • vic_325
                    • 264
                    just looking through this, seeing how 3" is too much for N/A, would dual 2.25" also be too much for N/A b35? right now i plan on matching it up to my stock dual 1 7/8" or what ever it is. but i want something more agressive. than stock.
                    i thought id just post here instead of make a new thread.
                    • vic_325
                      • 264
                      also what muffler? is there diferent flow ratings what works well? im knew to building exhausts
                      • E30SPDFRK
                        • 5715
                        Yes, far too big. If you want to do dual exhaust, 2" is fine (if a little on the large side) for an m30.
                        Although with dual, you get less efficiency than a single and it costs more, so I would recommend a single 2.5 setup. This is what I have and it is great.
                        You can run whatever muffler you feel like running.
                        Byron
                        Leichtbau
                        • vic_325
                          • 264
                          i guess its heavier to run a dual aswell. What do you have for a cat and resonator?
                          • Lurker27
                            • 821
                            Go with 3" for turbo, IMO.
                            '89 335is +turbo
                            • E30SPDFRK
                              • 5715
                              I'm running a high flow cat from a Dodge Charger (the lame 80's ones lol), no resonator to a Brullen straight through muffler. It's fucking loud.
                              I was running my stock 325e exhaust with no muffler before, and I felt an actual difference switching to the 1/2" larger tubing. Low end is just about the same, but top end pulls harder. And my top end was good before.
                              Byron
                              Leichtbau
