M30 exhaust size....
  • Zacm829
    • Jan 2008
    • 1919
    Originally posted by E30SPDFRK
    I'm running a high flow cat from a Dodge Charger (the lame 80's ones lol), no resonator to a Brullen straight through muffler. It's fucking loud.
    I was running my stock 325e exhaust with no muffler before, and I felt an actual difference switching to the 1/2" larger tubing. Low end is just about the same, but top end pulls harder. And my top end was good before.
    Do you have a sound clip on this?
    1987 325i-M60b44 swap
    • yert315
      • 2734
      I've got a 3" single exhaust, albeit with a 2 1/2" muffler (just to get it going for now). There's a guy in town with a 3" single from the headers back and it pulls strong (m30 e30). Of course, I have no frame of reference, but I don't see a problem running a 3" exhaust, especially if you plan on going FI.
      • E30SPDFRK
        • 5715
        Unfortunately no. My engine shit the bed the day after I got it on.
        I have some of the e exhaust though, which actually sounded pretty good.
        A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
        Byron
        Leichtbau
        • Zacm829
          • Jan 2008
          • 1919
          Interesting, What numbers did you put down on that dyno?
          http://s182.photobucket.com/albums/x...t=DSCI0119.flv
          • E30SPDFRK
            • 5715
            182hp 187tq
            Byron
            Leichtbau
            • BDK
              • Jul 2008
              • 684
              couple of questions all concerning N/A motors...
              1) How is two exhaust manifolds going into a single pipe more effecient than true duals?
              2) If the size of the exhaust manifolds are say 1 5/8" ID, why go out to 3", the restriction is at the exhaust port, if you can't increase that, does it really help to go out to bigger pipes???...
              FWIW, Hartge Headers are like 1 5/8" OD maybe 1 7/8" OD so going any bigger than 2"/2-1/4" seems abit ridiculous to me....
              If air flows like water,
              then going smaller to bigger would actually slow the flow,
              The same size or close to it would equal the flow coming out,
              going bigger to smaller would speed the flow as long as it is done gradually
              • BDK
                • Jul 2008
                • 684
                Going up in diameter also moves the torque band up at the expense of low end torque . Stock M30's are lacking in acceleration off the line so I wouldn't change the sizing unless you increased the HP dramatically.
                • Wh33lhop
                  • 11705
                  Yeah, those M30s sure are torqueless.
                  paint sucks
                  • BDK
                    • Jul 2008
                    • 684
                    I didn't say torqueless, but the torque range doesn't come on until like 3750 rpm,
                    abit high compared to modern cars,
                    so by increasing the tubing size you are now moving that to like 4250 simular to an S38.
                    fine if you know how to drive them, which I do, but a well tuned M30 will outrun an S38 stoplight to stoplight, it is the topend which puts the S38 over the top...
                    My point being,
                    most people here will not see 130mph,
                    so why not keep it "Quick" (more low end TQ) instead of "Fast" (more high end TQ)
                    • Wh33lhop
                      • 11705
                      Think of it in terms of cross section
                      You are going to have more cross sectional material (piping) for any given cross sectional area (exhaust gases) if you use two pipes, than one
                      This means
                      more surface area in contact with exhaust gases dragging the velocity down
                      more weight
                      In a single exhaust you need one more collector (2-1) than a dual configuration
                      But every properly designed dual exhaust has at least one H or X pipe and a single cat and muffler
                      Look at it this way
                      Higher exhaust velocity means higher exhaust pressure which means higher backpressure which, no, is never good.
                      Low exhaust velocity is not good either because you want a scavenging effect from the vacuum created by the inertia of the exhaust gases.
                      So you need a middle ground, an ideal exhaust velocity.
                      However, it looks like you've got a lot of misinformation
                      There are two stock exhaust manifolds and no one is talking about going to a dual 3" setup, that would be retarded. Already stated in this thread was that the maximum diameter you'd want for dual exhaust for an M30 would be about 2"
                      paint sucks
                      • Wh33lhop
                        • 11705
                        My point being,
                        The torque peak doesn't arrive until later, but that doesn't mean they're lacking in low-end. In fact, as I recall they're setup similar to the M20, with the first resonance of the IM being lower RPM and the second resonance coming on higher (close to 3500-4000). But don't quote me on that.
                        paint sucks
