M30 E30 official roll call thread
This is a sticky topic.
  • Tino-m30b35
    • Feb 2011
    • 56
    #91
    1987 325i(A) Coupe
    With 1989 735i(A) M30B35
    + M10 5spd box
    + 3.64 LSD
    + 173 ECU
    92 Opel Monza CLi 200i8v Exec
    92 Opel Rekord 380GSiV6
    87 BMW E30 335i (M30B35)
    91 BMW E34 520i (M50B20) with Mtech Turbines
    95 Hyundai Elantra with Mitsu 4G63
    Three Aircooled VW Beetles
    17.8Litres, 38cylinders, 10Cams and 84valves
    • martijn76
      • 15
      #92
      Engine is in the car, now getting it to run, no fuel yet..
      E30 1986 convertible
      e34 M30 1989 with '88 m20 loom
      Manual gearbox e34
      300mm.de enginemounts
      300mm.de 312/294mm Brakes
      Bilstein b6
      3.91 LSD
      • The Humjet
        • Jun 2010
        • 528
        #93
        Posting this on behalf of my friend
        89' e30 318I
        E34 m30 3.5
        m10 gearbox with spec stage 3 clutch (soon to be getrag 265) nothing wrong with m10 gearbox
        e30.de engine mount copies (position 3)
        323i auto tailshaft
        e30 320i loom
        3.15 open diff (LSD coming soon)
        Good fun lots of low down grunt. I'm trying to convince him to turbo it but he keeps saying no "I got no money".
        • jim325
          • 228
          #94
          Well, now that I have my car up and running for about 150miles I feel confident and posting in this thread.
          Specs:
          1989 325i Body.
          1986 535i Engine and radiator.
          1986 535i manual transmission with modified output shaft, whatever trans came in my M20 output flange and untouched 89 325i driveshaft.
          Qbang Motor Mounts in the rear most hole.
          AKG 75D Engine and Trans mount bushings.
          Peter Florance MS using Super ETA wiring harness.
          Good N Tight turbo exhaust manifold.
          Completley rebuilt block.
          JE forged picstons.
          ARP head studs.
          MLS head gasket.
          eBay turbo.
          2.5" intercooler piping.
          4"thick, 22"long, 9"tall eBay intercooler(emusa, I think those are the right measurements)
          eBay RS type BOV.
          Tial 38MM wastegate 9 PSI spring.
          Full 3inch exhaust, eBay cat, Magnaflow muffler.
          30 or 32 lb hr injectors(0 280 155 8110)
          Eibach pro-kit springs and drop hats in front with 3mm?pads, spring pads removed in rear. KYB shocks.
          205/50r16 crappy tires on fake style 5's.
          EDIT: Forgot, no A/C and no P/S. Electric fan mounted in front of the radiator.
          Engine bay wiring still needs to be cleaned up(it's done just gotta figure a way to hide it). Still doing some tuning but it's coming in nicely. Gonna try and put the MTech 2 front valence back on monday.
          CRAPPY iPod pics.
          Uploaded with ImageShack.us
          89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
          • kronus
            • Apr 2008
            • 13005
            #95
            our lemons car has moved under its own power tonight, so I feel like we can participate in this thread.
            old-ish pic, I'll get some better ones tomorrow
            motor, harness, ecu: m30b35 out of a 635csi
            motor mounts: copies of funkmasta mounts
            trans: e28 getrag 260/6 out of some dude's garage from under some 2x4s (he also gave me a metric mechanic M10 head)
            trans mount: stock
            driveshaft: '87 ETA big guibo
            shifter bits: stock e30 linkage. interestingly enough, we didn't need to shorten the selector rod, but that may be because we made a DTM-style mount out of an early sheetmetal console
            exhaust: stock headers and downpipes out of a e34 5-series into 2.5" single pipe with a resonator, y made out of junky bolt-on exhaust tip twinerator
            firewall modifications: ample
            race is this weekend! wish us luck!
            cars beep boop
            • csermonet47
              • Jul 2009
              • 937
              #96
              I suppose I belong here now.
              1991 E34 535i M30B35
              3.73 LSD
              Getrag 260/6
              Spec stage 1 clutch
              E24 Flywheel
              AKG Poly Engine and Trans Mounts
              M20 Harness
              Good&Tight Mounts in the rear position
              Are Three Vee
              Dad Spec
              • jim325
                • 228
                #97
                Clean install, looks way good.
                • spiDmang
                  • 3941
                  #98
                  84' 325e chassis
                  M90b35 (out of an 80' 635csi)
                  635csi g260/6 trans
                  3.25lsd
                  91' 318iS - S54/6MT Swapped
                  08' E90 M3 6MT - Daily
                  Originally posted by IronJoe
                  Originally posted by 2mAn
                  • jerbroc
                    • Sep 2006
                    • 8
                    #99
                    89 335is
                    M30B34 (from 86 535i) Purchased this motor fully rebuilt and cheap
                    5 speed Transmission (90 535i)
                    Motronic 1.3 (88 735il auto)
                    Wire Harness (88 325i)
                    front half of drive shaft (87 325es)
                    e28 Radiator
                    I took this week off to install it, it better be running by Sunday night since it was my only running vehicle.
                    So far old motor out and m30 ready to be rewired and installed.
                    • mcskibadee1
                      • Feb 2012
                      • 1379
                      #100
                      Thanks Chris at Castros for the MAF, CAI and exhaust. Drives beautifully!!!
                      TRANSACTION FEEDBACK HERE
                      FOR SALE ITEMS HERE
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #101
                        3.73 LSD
                        Getrag 260/6
                        Spec stage 1 clutch
                        E24 Flywheel
                        M20 Harness
                        How'd you get the m20 harness under the stock m30 injector harness plastic cover thingy? I thought it was attached to the m30 harness.
                        • csermonet47
                          • Jul 2009
                          • 937
                          #102
                          It is attached. I had to cut it all out then I just put the M20 harness in there and tried to make it all neat. I had to dremel out certain areas to allow plugs to fit. Here is what it is like underneath the box:
                          Are Three Vee
                          Dad Spec
                          • Bearmw
                            • 1323
                            #103
                            Well since I'm nearly done I guess I can post something:
                            89 Royal Blau vert with custom engine harness
                            B35 with 10.50 C.R. lightened and balanced stock rods (removed the pads on the big end)
                            worked head/N21 grind cam (simply beautiful courtesy of Paul Burke)
                            92.5 mm forged pistons which weigh 435 grams compared to stock 522 g.(also from Paul Burke)
                            standard size Glyco main and rod bearings
                            E28 535i radiatori
                            Getrag 260/6 from e34 with 533i flywheel balanced to E28 clutch & pp, UUC dssr
                            87 Eta big guibo driveshaft fits with no modification
                            home ported port matched intake, Bavauto long tube headers into y pipe with 2 1/2" single outlet to resonator to single inlet/outlet Walker muffler
                            3.5 Bar FPR gives about 50.8 psi so the injectors flow a bit over their 24 lb. rating.
                            67 mm bored throttle body
                            wide band o2 sensor
                            LS "D585 " truck coils on valve cover for sequential
                            Bosch 24 lb "715" injectors
                            home brew cold air box/filter setup with flow stack and SB cone filter
                            Revshift m20 motor mounts
                            E21 "green" transmission mounts
                            Rogue Engineering oil cannister cap with oil temp and pressure senders
                            MS3X in progress...
                            Otis' mounts in position 2 (gives me 1" between fan coupling on water pump and the radiator)
                            80 degree t stat
                            VR-1 20W50 oil
                            NGK BPR6ES plugs at .032"
                            I'm excited because next week I'm finally going for some dyno tuning. I had to track down a couple issues: fully bleeding the cooling system and not having one of the injector terminals fully seated. Oil temp and pressure looks good and my Spal fan kicks on and off as it should. Im going to a shop near Boston that has a Dyno Dynamics machine. They are supposedly known for low numbers /they calculate a 25% drivetrain loss so I'm interested in what numbers I get. Before that I am waiting on a new TPS to arrive because the current one has no continuity between pins 3 and 18 at full throttle and so the computer isn't getting the signal which means the tune that's in my chip isn't working to potential and is likely lean. Idle is currently Ok at about 900 rpm but I expect that too will improve because it seems a bit rich. I think the base 10 to 1 tune I got from Miller is for 19 lb. injectors. Most likely going to run near 50 lbs. of fuel pressure. I would like to run 91 octane but most of the stations don't have that grade; they have 89 and then jump to 93 so I will probably tune for 93. I'm going to keep a conservative redline of about 6500 rpm.
                            • tfritz
                              • Jan 2008
                              • 590
                              #104
                              Well it finally runs right, so I suppose it belongs here now.
                              m30b35
                              custom motor mounts
                              Resurfaced head (not a significant amount removed, you can still vaugely see the old gasket outline)
                              Reground valves
                              new valve seals (guides checked out within specs)
                              port matched
                              Ireland Engineering Dual Race
                              IE race rocker
                              IE 292 reground cam
                              oversized eccentrics
                              Korman adjustable cam gear
                              Factory Head gasket
                              ARP studs
                              Miller
                              Miller WAR chip
                              • Bearmw
                                • 1323
                                #105
                                Project Update: Finally got some dyno tuning done using the Miller WAR chip. I still have an intermittent misfire so I will have to recheck all ignition parts and also wiring. In any event; misfire aside the car is running good with 205.4 hp at about 5100 rpm's and peak torque of 240 ft/lbs at about 4050 rpm's on a Dyno Dynamics machine. I still have some exhaust restriction with the B35 manifolds as well as some pipe restriction before the y pipe so there is more power on the table. I haven't been able to find reasonably priced decent fitting headers yet...but in any event not too bad for an "agricultural engine".
