What does it take to get an N/A M30 to 300hp?
  • euroshark
    • Apr 2006
    • 3491
    #31
    Getting 300hp out of M30 with sensible money is impossible.
    Bingo
    You will likely need triple Webers or ITBs.
    • der affe
      Technical
      • Dec 2005
      • 8452
      #32
      what car does the s-38 come out of?
      • euroshark
        • Apr 2006
        • 3491
        #33
        E28 M5s, E24 M6s, E34 M5s. Personally, I think it would be absolutely ridiculous to remove the motor from any of those cars, especially to put it into an E30... But that's me.
        • whiltebeitel
          • Apr 2007
          • 2098
          #34
          unless the frame was already damaged... looks longingly at the e28 M5 at work, trying to ignore the price of a rebuild...
          '89 325i track sloot
          '01 530i daily
          -Enginerd
          • der affe
            Technical
            • Dec 2005
            • 8452
            #35
            does the m-30 suffer from the same rocker whoes as the m-20 when you ring it out?
            • euroshark
              • Apr 2006
              • 3491
              #36
              It can, but I have not heard very many people complain about like the M20s. A Dinan chip raises the rev limit of the US spec B34 to 6700rpm, which is probably as high as you will ever need to go on an M30! To breathe efficiently enough to make those revs practical you will need a good cam and some nice headers.
              • der affe
                Technical
                • Dec 2005
                • 8452
                #37
                that's the plan:
                3.5 m-30
                *IE headers
                *dbilas itb's (already have them on my m-20 just need new manifold for the m-30)
                *wolf standalone/speed density conv (no maf)
                *schrick or catcams 290something deg cam
                *P&P head
                *GLH exhaust with cat bypass (bolt in and out cat)
                sound good....?
                would like to get as close to 300hp as possable w/o replacing the pistons to raise the compression
                • Jonsku
                  • Oct 2004
                  • 566
                  #38
                  Originally posted by der affe
                  that's the plan:
                  3.5 m-30
                  *IE headers
                  *P&P head
                  sound good....?
                  M30B34 out of E28 has 10:1 CR, at least here in Europe.
                  That sounds good but i doubt it'll make 300hp, more likely 260-270hp.
                  Anyways, take lot of pictures and tell us how it's going :-)
                  - E34 M5 (x 2) -
                  - E30 V8 Cabrio "Kylpyamme" -
                  - Alpina D10 Touring #33/94 -
                  - E46 318i Touring -
                  - Toyota Hiace 4wd -
                  • JMil86
                    • Dec 2008
                    • 558
                    #39
                    Wouldn't a 10 to 1 power to weight be about 270 hp? Give or take?
                    Nio är livets tal.
